Classic Audi » Technical » Mech/Tech » Electrical problems » electrical gremlins?
Old 19-11-09, 05:49 PM   #1
Gaz
Gaz's Avatar
Unhappy electrical gremlins?
found some electrical gremlins in the car the other day,
Firstly, the radiator fan is intermittently turning its self ON/OFF for no reason.. even when engine is cold.
I can hear something in the fuse box clicking on and off while its doing this.. Is it a relay?
Secondly, the front window wipers only work at full speed.. but not at slow or intermittent speed. They also don't want to come to rest at the bottom of the windscreen when you turn them off.
These are all the gremlins i've noticed so far, but there maybe others I haven't noticed yet.
any help will be much aprecated.
Thanks, Gaz.
Old 19-11-09, 06:09 PM   #2
vag80
vag80's Avatar
that sounds like a relay playing up
200k club member
87-b3 80
83-4000 2 door
Old 19-11-09, 06:17 PM   #3
Yes or the fan switch it's self
Old 19-11-09, 06:38 PM   #4
vag80
vag80's Avatar
if the wipers only work on fast and don't park it's a good chance it's the relay,as for fan could be switch,
relay or a wiring fault
200k club member
87-b3 80
83-4000 2 door
kv engine gremlins irish80sport Engine 9 01-11-09 08:31 PM
Electrical gremlins strike again Emjay Electrical problems 1 17-05-09 07:50 PM
80 Sport Electrical Gremlins b2_sport Electrical problems 9 19-04-09 10:12 AM
electrical fault bart simpson Engine 2 20-02-09 11:31 PM
electrical fault bart simpson Electrical problems 3 17-02-09 09:08 PM
