Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,145 Currently Active Users: 8227 (2 members and 8225 guests) Welcome to our newest member, BuddyInons |
my 2.2 kv engine has a knocking noise in the bottom of it, its in and out of it all the time, any ideas whats wrong? mechanic cant pinpoint it. it taps for a minute or so then stops for another minute or so? im not happy, was just getting excited about getting the bloody thing on the road
And to make thinks worse my 80sports oil light flashes on for a second even though its full of oil![]() any thoughts would be much appreciated. |
Knocking at the bottom of the engine would indicated big end shells............but I am not a mechanic
Sounds like a big end from your description if it is i do have a spare engine from a 1984 coupe
Could be a worn bottom end, but could be thrust washers are worn allowing the crank to float and knock.
Either way, needs fixing before it gets any worse. |
im hoping i wont need that new engine, im guessing postage would be a bitch to ieland
il just keep my fingers crossed that it goes out of it with a bit of a drive( unlikely, but it will make me sleep better tonight)im guessing if i need bits for the engine audi wont have them? |
that sounds like an engine rebuild coming on i wouldn't drive it till i found out were the knock is coming from
nothing like a bit of deep dish200k club member 87-b3 80 83-4000 2 door
sounds like big expense, mite just cut my loses and forget about it. its hard to pinpoint, i presumed when it was intermitent that it would be an obvious problem bu apperantly not!!!
The only sure way,would be to strip and inspect.
I,ve had 4 KV engines(one with 175,000 mileage) and only had noisey tappets. Unlucky for you,unless someone,s worked on yours and cocked up.Or its been badly treated,no oil and filter changes? |
most common fault is the oil pick up being blocked
thought at first it was tappets, but its not, i only bought it and really dont know the history of it before it came to ireland the guy i bought it from had it stored in a shed for 2 or 3 years. exaust was busted so we didnt hear the tapping until it was fixed.
| electrical gremlins? | Gaz | Electrical problems | 3 | 19-11-09 06:38 PM |
| cam for a kv engine | ferris360 | Engine | 4 | 03-06-09 08:13 AM |
| Electrical gremlins strike again | Emjay | Electrical problems | 1 | 17-05-09 07:50 PM |
| 80 Sport Electrical Gremlins | b2_sport | Electrical problems | 9 | 19-04-09 10:12 AM |
| 20v engine | quattropower | Parts Wanted | 2 | 23-01-09 11:00 PM |
