Classic Audi » Technical » Mech/Tech » Engine » 80 Quattro KK engine won't start
Old 06-06-12, 09:24 PM   #31
That lower one is the original VAG 2xxx tool?
Old 07-06-12, 12:29 AM   #32
urS6
Yes. I've never bothered with it - I just use a huge 3/4" Norbar industrial torque wrench set to 450 Nm (with the 2079, it's a mere 350 Nm). Check the torques for your engine - they may be different.
The crank-locking tools (2084 or 3256 depending on engine) are invaluable.
Here are a couple of related links:
http://www.s2-audi.co.uk/tech_articles/useful_tools.htm
http://www.vag-data.com/audi100A6/Power_unit/AAR/A.en-GB.4A-MM-MMAAR.wi__20832238[1].html
There are lots of timing belt R&R writeups on the Internet. Anything by Scott Mockry, Fred Munro or Dave Forgie is generally excellent.
urS6 is offline   Reply With Quote
Old 07-06-12, 02:26 AM   #33
SE_30
SE_30's Avatar
Nice one glad you have it running. Give Pete Reeve at quattro corner a call he should be able to source all your parts in future if needed.
http://www.quattrocorner.com/
0121 476 0034
B2 90 quattro; next project
B2 90 quattro; half dead
Old 07-06-12, 07:00 AM   #34
Mike671
Yep you got it it's 2079 and 2084 (that right for the kk?!) also found 3034 to remove idler as opposed to levering it. Ok mate I'll give him a call at somepoint :-)
Mike671 is offline   Reply With Quote
Old 07-06-12, 07:47 AM   #35
As said, the 2079 doesn't really get used unless the car is on a lift. There's no room for the tool and the torque wrench.
I had one but sold it as it didn't get used
1991 90 quattro
Old 07-06-12, 08:23 AM   #36
Mike671
Yup I know that as when I moved belt around to get it running I just used a socket the other day plus these tools are free, all I'm wondering is 2084 correct for locking the KK crank pulley
Old 07-06-12, 08:29 AM   #37
urS6
Yes - I used to use the 2084 on the KK in my old 80q. The U-shaped end fits around a very solid aluminium casting bolted to the engine (snub mount?). Be prepared to use over 1000 Nm undoing it depending on when it was last done and what kind of paste was used over what region of the bolt.
Old 07-06-12, 12:48 PM   #38
Mike671
Ok cheers mate I have a 5.5 foot 3/4 drive snap on breaker bar hope that should do it lol
Found the other tool anyway
And this lot just turned up :-) gunna be a busy evening!
Think I better start a project thread :-D
Old 07-06-12, 04:10 PM   #39
urS6
Ok cheers mate I have a 5.5 foot 3/4 drive snap on breaker bar hope that should do it lol.
Last one I did a few months ago, I used a 6 foot scaffold pole over the end of a 3/4" breaker bar. It was sticking up at an angle of about 30 degrees from the vertical, and I was dangling off the end - I reckon that meant that I was exerting a torque of 1000 Nm. It wouldn't shift until I started bouncing up and down. Then there was an almighty bang and I suspected that I had sheared the crankshaft! I hadn't - that's just the noise it made when it came undone.
And this lot just turned up :-) gunna be a busy evening!.
That's the 3256 (for later engines with the different harmonic balancers), the 2079 (that most people do without) and the 2084 for the early engines.
I presume the jig on the bottom left is the idler wheel puller - not seen one before - can't remember how easy it was to get the wheel off without the special tool which probably means it was easy!
If you do all that in an evening, I'll be impressed!
Paul
