80 Quattro KK engine won't start
Right ok it's been sat for awile matey I got it off reckon he last started it one year ago though. Spark is lovely that's all there, compression is nice and strong around 13 bar per cylinder, so I'm guessing it's fuel well you crank it over first time and you have pressure of around 130-140 psi on line out the pump, but no fuel out the metering head on crank, is this correct? the cold start valve spits fuel but it doesn't even hesitate to start. So then I placed fuel pressure guage on line out metering head no pressure on crank, but lift metering head flap slightly first time of cranking you have no pressure let off the key pressure builds to around 30 psi then turn key again and you have around 60 psi. Can someone help me out? As k jet is doing my head in I would love to hear it run :-( and yes it has fresh fuel in it
