Classic Audi » Technical » Mech/Tech » Engine » lack of heat
Old 03-02-15, 08:00 PM   #21
Flying Frank
Flying Frank's Avatar
Guess we are all spoilt now, but again going back to my first car , a 1939 Austin 8, standard kit was a blanket and overcoat in Winter driving conditions. Plus a portable radio ( eventually) on the back window shelf which would slide from side to side as you went around corners ( on two wheels of course! ) One windscreen wiper and on dipped beam, only one headlight....ah, those were the days....
Old 05-12-16, 09:09 PM   #22
andya
andya's Avatar
I'm going back to my old thread, more than a year since I started it. I never did tackle it, and last weekend I had a little tinker with it.
I checked the 2 hoses that go into the matrix. The car had been driven, the engine hot - I found the top hose warm, but not hot to the touch. The bottom one however was red hot. Is there anything here that should set alarm bells running?
The heater valve at the back of the head is operating ok.
If the weathers ok at the weekend I'm going to loosen the jubilee clip for the hose into the matrix and see if there's an airlock....
Any other tips??
Many thanks
Andy
1985 Coupe Quattro
1986 Coupe 1.8 weber carb
1987 Coupe 2.2 GT
Old 05-12-16, 09:13 PM   #23
Andy10v
Andy10v's Avatar
Heater matrix clogged up?
2005 350z GT
Sold-1993 ABY coupe
Old 05-12-16, 09:16 PM   #24
andya
andya's Avatar
That's what I fear. It's looks an absolute pig to get to....
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 05-12-16, 09:25 PM   #25
Hanuman
Hanuman's Avatar
Disconnect the matrix, and see if you can back feed with a hosepipe? Is there any sign of the car having had a coolant issue, with something like bars leaks being used?
Old 05-12-16, 09:25 PM   #26
Andy10v
Andy10v's Avatar
You could do a quick flow check with a hose if you are prepared to top up and bleed the system afterwards.
2005 350z GT
Sold-1993 ABY coupe
Old 05-12-16, 09:48 PM   #27
andya
andya's Avatar
Thanks for your replies, I'll try your suggestions at the weekend.
Cheers
Andy
1985 Coupe Quattro
1987 Coupe 2.2 GT
