Classic Audi » Technical » Mech/Tech » Engine » kv engine gremlins
Old 01-11-09, 12:31 AM   #1
irish80sport
irish80sport's Avatar
Default kv engine gremlins
my 2.2 kv engine has a knocking noise in the bottom of it, its in and out of it all the time, any ideas whats wrong? mechanic cant pinpoint it. it taps for a minute or so then stops for another minute or so? im not happy, was just getting excited about getting the bloody thing on the road And to make thinks worse my 80sports oil light flashes on for a second even though its full of oil
any thoughts would be much appreciated.
irish80sport is offline   Reply With Quote
Old 01-11-09, 09:24 AM   #2
Knocking at the bottom of the engine would indicated big end shells............but I am not a mechanic
Old 01-11-09, 01:54 PM   #3
steveb
steveb's Avatar
Sounds like a big end from your description if it is i do have a spare engine from a 1984 coupe
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 01-11-09, 03:25 PM   #4
Could be a worn bottom end, but could be thrust washers are worn allowing the crank to float and knock.
Either way, needs fixing before it gets any worse.
Old 01-11-09, 07:26 PM   #5
irish80sport
im hoping i wont need that new engine, im guessing postage would be a bitch to ieland il just keep my fingers crossed that it goes out of it with a bit of a drive( unlikely, but it will make me sleep better tonight)
im guessing if i need bits for the engine audi wont have them?
Old 01-11-09, 07:31 PM   #6
vag80
vag80's Avatar
that sounds like an engine rebuild coming on i wouldn't drive it till i found out were the knock is coming from
200k club member
87-b3 80
83-4000 2 door
Old 01-11-09, 07:35 PM   #7
irish80sport
sounds like big expense, mite just cut my loses and forget about it. its hard to pinpoint, i presumed when it was intermitent that it would be an obvious problem bu apperantly not!!!
Old 01-11-09, 07:50 PM   #8
The only sure way,would be to strip and inspect.
I,ve had 4 KV engines(one with 175,000 mileage) and only had noisey tappets.
Unlucky for you,unless someone,s worked on yours and cocked up.Or its been badly treated,no oil and filter changes?
Old 01-11-09, 08:19 PM   #9
steveb
steveb's Avatar
most common fault is the oil pick up being blocked
[FONT]
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
Old 01-11-09, 08:31 PM   #10
irish80sport
thought at first it was tappets, but its not, i only bought it and really dont know the history of it before it came to ireland the guy i bought it from had it stored in a shed for 2 or 3 years. exaust was busted so we didnt hear the tapping until it was fixed.
electrical gremlins? Gaz Electrical problems 3 19-11-09 06:38 PM
cam for a kv engine ferris360 Engine 4 03-06-09 08:13 AM
Electrical gremlins strike again Emjay Electrical problems 1 17-05-09 07:50 PM
80 Sport Electrical Gremlins b2_sport Electrical problems 9 19-04-09 10:12 AM
20v engine quattropower Parts Wanted 2 23-01-09 11:00 PM
