Classic Audi » Technical » Mech/Tech » Electrical problems » Power loss
Old 27-05-20, 09:07 PM   #1
Alan
Alan's Avatar
Default Power loss
Hello all.
Driving yesterday had a sudden loss of power for a milly second the abs light came on then off. This happened 5 or 6 times. Got home parked up then tried to start up nothing happened. Checked battery put jump leads on still nothing. Would the starter cause this as i have short cut power to it and it seems dead. Or could battery be fried?
Thanks.
Alan is offline   Reply With Quote
Old 27-05-20, 09:24 PM   #2
steveb
steveb's Avatar
What car and year are we talking about ur quattro ?
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 27-05-20, 09:27 PM   #3
Alan
Alan's Avatar
1997 cabriolet.
Old 27-05-20, 09:49 PM   #4
ABS light will come on if you drop below 12v.
When you say nothing happens, does it turn over or is it totally dead ?
If it's not even turning over, I'd suspect a battery or a bad earth.
Even if a battery shows 12v, it can still be goosed and be unable to provide enough juice to turn the starter.
1991 90 quattro
Old 27-05-20, 09:58 PM   #5
Alan
Alan's Avatar
Totally dead. Will not even take a jump from my van.
Old 27-05-20, 10:45 PM   #6
Ben
Originally Posted by Alan View Post
1997 cabriolet.
It could be the ignition switch.
1992 80 quattro 20vt
Old 28-05-20, 10:41 AM   #7
steveb
steveb's Avatar
I would be checking the battery first
[FONT]
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
Old 28-05-20, 01:03 PM   #8
BackintheFold
BackintheFold's Avatar
that.s my first thought too-especially if you hang a heavy set of keys off of the ignition key
Old 28-05-20, 01:07 PM   #9
Alan
Alan's Avatar
Thanks.
I wouldn't have thought to have a look at the ignition switch.
Old 29-05-20, 04:54 PM   #10
Alan
Alan's Avatar
Back again.
Have put on new battery, cleaned earth on battery lead,checked ignition.
The lights, wipers etc are working until turnover position.
The abs unit is clicking when the key is turned don't know if this is normal.
I'm leaning towards starter now,but would that lead to power loss when driving?
Any thoughts welcome.
Thanks.
