Classic Audi » Classifieds section » Parts Wanted » 100Q avant c3 1989 Brake Master Cylinder
Old 21-02-17, 05:05 PM   #1
Arch_80
Arch_80's Avatar
Default 100Q avant c3 1989 Brake Master Cylinder
Hell everyone,
I have recently bought a rough old 100 to restore and have come undone with trying to replace or repair the ATE brake master cylinder.
I looked up the numbers and none match what was on the car. See pics attached
Please help as I'm at the stage of giving up.
Arch_80 is offline   Reply With Quote
Old 21-02-17, 05:40 PM   #2
I'd say you need to be forthcoming with a little more info-
http://audi.7zap.com/en/rdw/audi+100...6/611-53000/#1
This lists 6 options of cylinder, of which 5 also show as LHD.
Old 23-02-17, 03:45 PM   #3
Arch_80
Arch_80's Avatar
Hi many thanks for attachment, however, the six listed master cylinders do not match.
Old 23-02-17, 03:48 PM   #4
So, what Is the part number of the cylinder that you have removed?
Old 23-02-17, 03:59 PM   #5
Arch_80
Arch_80's Avatar
Unfortunately I can't work that out. It doesn't seem to be written on it or my likely it's beyond me haha.
What I can read is:
Top front: 25ZV
Top back: 03
Underside: 111/12 & 06 87 & (symbol) 17 - see above attached photo.
Back: (pressed/stamped) 08186G
Old 23-02-17, 04:14 PM   #6
I'd have a chat with Peter Reeve/quattrocorner, if the local dealership(if there is one) can't help.
By its format, I'd guess the number 08186G might be ATE's number.
Old 23-02-17, 05:06 PM   #7
From that list then it can only be 893 611 021 yes?
This any use.... https://www.amazon.co.uk/s/ref=nb_sb...Ck%3A893611021 ......clicking on the picture reveals that it also fits a multitude of other Audis.
Old 23-02-17, 09:47 PM   #8
But that would make it a 23.8 bore which will be wrong.
I'd expect a 25.4mm master cylinder on this car. The 25ZV would appear to back this up. 0687 is the month of manufacture
Have you tried contacting ATE in Germany. They're usually very helpful
Old 27-02-17, 11:53 AM   #9
Arch_80
Arch_80's Avatar
Thanks chaps. All good thoughts and help there. It is much appreciated and welcomed.
I have had word back from ATE who are all too happy to help, which is nice!
The suggested solution is to replace my original ATE 03.2125-2711.3 (discontinued part - not even on classic catalog) with ATE 03.2125-3210.3 (or for short ATE 010212 or for VAG 441 611 021 with or without the A after con't tell the difference other than car model).
The problem is that the FL measurement of my old ATE 03.2125-2711.3 is 14mm (ish/approx) and the newer with ATE 03.2125-3210.3 has an FL of 36mm.
So at the bottom of the email with no explanation are further part numbers. I assume this is part of the adaption kit. The following parts number and names are:
Zwishenstuck (aka intersection/intermediate piece) VAG 443 611 105
Flansch (aka flange/compensating piece) VAG 853 612 129.
Can we assume that this is now resolved?
Old 27-02-17, 01:10 PM   #10
Yes - I think you use a spacer to take up the difference.
