Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,152 Currently Active Users: 10144 (1 members and 10143 guests) Welcome to our newest member, BuddyInons |
Hi,
I'm after a gearbox for a B4 80 2.8 quattro, it's the same as the Coupe quattro 2.8 and has the code CBR stamped on it. Thanks |
Ive got one from an A4 2.8q with really low miles on it,wouldn't want much for it.its the same fitment,just might have very slightly different ratios on a couple of gears
just had a look and the cbr was also fitted to some a4qs so may even be the same one I have,i will have a look later Last edited by spink; 19-06-14 at 08:54 AM. |
Hi
im got one from a Audi 100 quattro will check code but think its the one you are after £50 how that sound? cheers john ![]() |
Hi
looks like code is CAB is that goimg to work located in Shipley cheers john |
Thanks for the replies guys, I need to do some research. I do know the diff ratio wasn't widely used and the very late cq 2.8 had a different code as the casting for ProConTen cables was removed. I'll get back to you.
thats a good point,mine is out of an R reg so won't have the holes probably
Hi
where you located i got a mate who breaking up a 2.8 V6 B4 quattro....................he located in Harrogate i cant get hold of him at mo.......but you need to remove from car,...........the engine is already removed. PM me if interested cheers john ![]() |
ive got one from a 95 80 2.6 quattro if any good?
#9 | |
Wrong diff ratio as well unfortunately, the 2.8 seems to use a pretty unique ratio. |
Still looking if anyone can help?
