-   -   B4 80q/Cq 2.8 V6 gearbox (CBR) (http://www.classic-audi.co.uk/forum/showthread.php?t=30325)
A80QAAH 19-06-14 07:42 AM
Hi,
I'm after a gearbox for a B4 80 2.8 quattro, it's the same as the Coupe quattro 2.8 and has the code CBR stamped on it.
Thanks
spink 19-06-14 08:51 AM
Ive got one from an A4 2.8q with really low miles on it,wouldn't want much for it.its the same fitment,just might have very slightly different ratios on a couple of gears
just had a look and the cbr was also fitted to some a4qs so may even be the same one I have,i will have a look later
JMLAudi 19-06-14 08:54 AM
Gearbox
Hi
im got one from a Audi 100 quattro
will check code but think its the one you are after
£50 how that sound?
cheers
john:halo:
JMLAudi 19-06-14 08:57 AM
Hi
looks like code is CAB
is that goimg to work
located in Shipley
cheers
john
A80QAAH 19-06-14 09:07 AM
Thanks for the replies guys, I need to do some research. I do know the diff ratio wasn't widely used and the very late cq 2.8 had a different code as the casting for ProConTen cables was removed. I'll get back to you.
spink 19-06-14 09:11 AM
thats a good point,mine is out of an R reg so won't have the holes probably
JMLAudi 19-06-14 11:57 AM
Hi
where you located
i got a mate who breaking up a 2.8 V6 B4 quattro....................he located in Harrogate
i cant get hold of him at mo.......but you need to remove from car,...........the engine is already removed.
PM me if interested
cheers
john:halo:
shaun5 19-06-14 04:49 PM
Originally Posted by JMLAudi (Post 355358)
Hi
where you located
PM me if interested
cheers
john:halo:
ive got one from a 95 80 2.6 quattro if any good?
A80QAAH 20-06-14 07:51 AM
Hi
where you located
PM me if interested
cheers
john:halo:
I've looked into it and the 100q uses a different diff ratio so is no good, but that one sounds perfect, I'll PM you now.
Wrong diff ratio as well unfortunately, the 2.8 seems to use a pretty unique ratio.
A80QAAH 02-08-14 02:20 AM
Still looking if anyone can help?
