Classic Audi » Classifieds section » Parts Wanted » B3/4/S2 aux gauge loom
Old 17-05-14, 10:59 AM   #1
Jolfa
Default B3/4/S2 aux gauge loom
As per title, just need the short bit of loom that joins the dash to the 3 extra gauges.
Would consider buying gauges with them for the right price if you'd rather not split?
Jolfa is offline   Reply With Quote
Old 17-05-14, 02:09 PM   #2
I've got one somewhere in the garage from a B3 Sport that we broke a couple of years ago I'll have a look for it
Old 17-05-14, 07:59 PM   #3
JoshB3audi
Hybrid Hater!!!!
JoshB3audi's Avatar
I did this to my B3 some of the wiring should be there for the lighting and volt meter but i had to run new feeds from the oil pressure sensor and oil temp sensor and just used insulated spade connectors
Mr Sarcastic!!!!!!!!
Old 18-05-14, 12:29 AM   #4
Jolfa
Its all there, I just managed to melt the original loom by mistake
Old 18-05-14, 10:10 AM   #5
Depends on model and model year, I presume - what might be there is white 6 pin plug that carries ignition, ground, illumination, speed signal, power for cigarette lighter and something else I've forgotten...
