Classic Audi » Technical » Mech/Tech » Engine » Halfords OAT antifreeze?
Old 25-01-16, 02:39 AM   #21
Gaz
Gaz's Avatar
Sounds about right!! So G12/13 is a long life anti-freeze but not of the OAT type? So the OP would want this stuff.
Interesting stuff about the fuel.. however, back to the antifreeze,
From what ive just been reading online, G12 audi coolant is OAT based.. apparently.
Also, the new G13 coolant is OAT too, except it also containes silicate? So does that mean its a HOAT? hybrid?
So if you are using G12, you have been using OAT based coolant for a while. ???????
Old 25-01-16, 08:08 AM   #22
Just checked the handbook for my CQ.
Correct antifreeze is G11 and is glycol based. I think VAG seem to have confused the market place with their G numbers?....and then there's different colours etc used by different manufacturers.
Minefield!!!!......that's an understatement!
Old 25-01-16, 08:42 AM   #23
Mellis46
Aero Advocate
Mellis46's Avatar
Well feck it then.
You cant buy G11 from Audi as they sell you G13. If what you have discovered is correct, then I have been using oat for 15 years plus with no ill effects. I certainly wont be draining it out and putting the blue stuff back in
My 90 manual says G11 but also gives a minimum specification TL-VW 774 A, apparently G13 is backwards compatible with that and all the way up to TL-VW 774 G?? Always relied on that being true...
Found this: http://forum.skodahome.cz/index.php?...tach_id=313169
As I understand the above, albeit it gets a bit technical at the end, all are ethylene glycol based and from googling the relevant numbers:
Type C / G11, Type F / G12+, Type G / G13.
There are no caveats on the sheet to say that G13 cannot be used in older engines, if anything it is better for aluminium! (Think Gaz said that at the start).
The Halfords oat seems to conform to TL-VW 774 D, which google says is G12.
Maybe at least we finally have an answer and can put the oat mystery to bed! Or do we?!
Would be interested to see impirical evidence of the audi supplied oat eating a copper (or otherwise) engine component within the parts service life (i.e its happened to them not some geezer down the pub or some dub-with-a-pineapple-on-the-roof-er)...
