Classic Audi » Technical » Mech/Tech » Engine » Halfords OAT antifreeze?
Old 23-01-16, 11:17 AM   #11
Sounds about right!! So G12/13 is a long life anti-freeze but not of the OAT type? So the OP would want this stuff.
Old 23-01-16, 11:36 AM   #12
Mellis46
Aero Advocate
Mellis46's Avatar
If we can infer that from my waffle... Just what I have done myself on my b3s and now the b5 - i try and do the right thing by them
Old 23-01-16, 05:29 PM   #13
ChrisG
ChrisG's Avatar
It's a minefield !
The blue stuff has to be changed every 3 years or so as it 'looses' ( I believe) something that makes it anti FREEZE, the glycol ??
Anyway as I don't mind changing mine ( I always seem to be doing something that results in loss of coolant , rad, stat, hose, oil heater/cooler by filter) so it's never been a real issue
It's a bit like the ethanol in the petrol these days, I use an additive , just in case.
B2 Sports were not built for unleaded let alone this other stuff
Old 23-01-16, 07:38 PM   #14
Gaz
Gaz's Avatar
Exclamation
Originally Posted by ChrisG View Post
It's a minefield !
Why do they put Ethanol in the petrol these days?
Also, I thought 80's 5 cylinder audis had hardened valve seats, and were designed for unleaded fuels???
Old 23-01-16, 07:48 PM   #15
Anyway as I don't mind changing mine.....
Me neither, it's not really a hassle every couple of years.
Old 23-01-16, 08:22 PM   #16
ChrisG
ChrisG's Avatar
They may be ok for unleaded but they are not OK for the low octane that comes with unleaded !
Ethanol ? think it's to do with getting a cleaner exhaust, it makes the exhaust gas smell very different, notice it evertime I back the car out !
Edit -- I should have said they weren't built for the low octane of unleaded !
Old 23-01-16, 09:48 PM   #17
Gaz
Gaz's Avatar
Oh.. i see.
Well, isnt that why it says 98 ron minimum or something like that on the filler flap?
Surely it just needs super unleaded?
Old 23-01-16, 10:25 PM   #18
ChrisG
ChrisG's Avatar
For starters
http://www.millersoils.co.uk/automot...-additives.asp
Old 23-01-16, 10:34 PM   #19
Andy10v
Andy10v's Avatar
back in 2009 all EU member states signed up to the Renewable Energy Directive, which requires 10% of road transport energy to be from renewable sources by 2020. The current UK minimum required by the Renewable Transport Fuels Obligation is 4.75%. - See more at: http://www.whatcar.com/car-news/new-....BQ5tXRn6.dpuf
Ethanol has about 30% less energy than petrol for the same volume, so you need to inject more, and will get lower mpg.
Running E85 on turbo cars can have power benefits as you can run more boost/timing due to the octane and cooling effect. (if you map for it and have the injector size to take advantage)
As for coolant I just use the Audi stuff and keep a few bottles in the garage as you will always need it for some unforeseen event.
2005 350z GT
Sold-1993 ABY coupe
Old 23-01-16, 10:35 PM   #20
Ringmaster
Ringmaster's Avatar
I believe the Ethanol content in our petrol is currently still 5%, with 10% planned for the future.
Do you really need to use an additive with 5%?
