Classic Audi » Classifieds section » Parts Wanted » 80/90 saloon injection fuel tank
Old 14-01-09, 05:39 PM   #1
Addicted
Default 80/90 saloon injection fuel tank
Bit of a long shot I know, but my 80 carb has only 6mm return and 8mm feed from the tank, not nearly enough for my new engine. I can see on EKTA that the injection cars have tanks with much larger return/feed lines..
I know I could modify the existing tank, but if someone has an injection tank I'd like to hear from them..
1985 Type 81 2 door 2.8 V6
1983 Golf GTI track weapon
1977 Scirocco G60
1968 Sand Rail
Old 14-01-09, 05:42 PM   #2
even longer shot for you.... have a spare WR quattro tank... could this be of use??
Old 14-01-09, 05:51 PM   #3
Addicted
The coupe part numbers on EKTA are different, the image is the same but the number isn't, I suspect the shape is different because of the quattro floorpan..
1977 Scirocco G60
1968 Sand Rail
Old 15-01-09, 12:04 AM   #4
90Quattro
90Quattro's Avatar
the quattro tank is in the boot and IIRC yours be underneath the car?
Old 15-01-09, 06:02 AM   #5
Typ 81/85 and Typ 89 (Series 2 and 3) the boot is behind the rear seats.
Series 4 ("new" grill) from about 1992 J reg onwards had it under the floor, hence they could introduce the avant version.
Old 15-01-09, 08:13 AM   #6
do ya think someone at Audi suddenly had a brainwave with the 80 and realised after 15 years with an estate model in the 80 range that they could by just moving the fuel tank??
and as Pimp says, the fuel tank is in an uprite position behind the rear seats. On the plus side of this, you get a really deep boot space!
Old 15-01-09, 08:40 AM   #7
Good morning sunshine
B2 or B3? Q or fwd?
Old 15-01-09, 11:02 AM   #8
Puglife
==>PUGSPORT!<==
Puglife's Avatar
i have an audi 80 quattro saloon fuel tank. mounts behind rear seats same as all quattros.
Old 15-01-09, 01:35 PM   #9
90Quattro
90Quattro's Avatar
I stand corrected Steve couldn't quite rememeber just know boot was bigger/deeper in my 80. I wish was under floor as boot in quattro really is rubbish.
type 43 metering head for fuel injection unit jack1 Parts Wanted 10 15-11-09 09:13 AM
Fuel tank and MOT andy Engine 12 31-10-09 07:41 PM
ally fuel tank andy Engine 6 03-08-09 09:04 PM
Electronic Fuel Injection K-Jetronic-equipped engines amanda Technical Info 5 19-07-08 07:52 PM
Flushing out fuel tank randall977 Engine 6 20-10-07 11:00 PM
