Classic Audi » Technical » Technical Info » Electronic Fuel Injection K-Jetronic-equipped engines
Old 01-07-08, 02:05 PM   #1
Default Electronic Fuel Injection K-Jetronic-equipped engines
Found this in an old copy of "practical classics" and thought it may be of use to someone
Old 01-07-08, 02:12 PM   #2
4v6
Pedant mode on: K jet is hydro mechanical....Mode off.....
Good article tho it pretty much shows it how it is.
Old 18-07-08, 07:35 PM   #3
hmm this looks usefull
hmm pity you cant read it!!
Old 19-07-08, 08:11 AM   #4
61 stu
61 stu's Avatar
save it as a picture then insert it on a new page in word and you can have it as big or as small as you like!
edit: i take that back, even when you put it on word and make it bigger its still pretty illegible, bugger!
61 stu is offline   Reply With Quote
Old 19-07-08, 08:29 AM   #5
Hmmmmm will look into this, I sacnned it at a hi res so it should be fine if you pm me I will send the original scans to you.
Old 19-07-08, 07:52 PM   #6
moomin
click on image then click the zoom people!
moomin is offline   Reply With Quote
type 43 metering head for fuel injection unit jack1 Parts Wanted 10 15-11-09 09:13 AM
80/90 saloon injection fuel tank Addicted Parts Wanted 8 15-01-09 01:35 PM
Electronic music 4v6 General Chat 2 13-11-08 11:15 PM
Jetronic Fuel Metering Head / Air Flow Meter randall977 Parts Wanted 5 17-12-07 04:26 PM
Jetronic fuel accumulator.... randall977 Engine 0 15-12-07 03:59 PM
