Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,120 Currently Active Users: 4521 (0 members and 4521 guests) Welcome to our newest member, BuddyInons |
Hi. I have a problem with my 1993 Audi. When it's cold and when driving around town, when I take my foot off the throttle car is still going for about 3 seconds, but on motorway everything is fine. I checked for leaks around inlet manifold and vacuum system seems to be in order too, and another thing is at some point when engine is cold RPM will jump between 1100rpm and 1200rpm for some time and then stop. I just have no idea what it can be. Maybe someone can help me with that? Thanks in advance.
EDIT : Engine code is ABC. |
Have you tried cleaning out the idle stabilizer valve with WD40? : http://www.12v.org/engine/index.php?...n=cl&view=rear
1992 80 quattro 20vt |
#3 | |
I did clean it, but nothing changed. Bought a new one, still, no luck!
Is it manual or automatic?
Too many cars!! |
Temp sender that controls,the ISV?
I swopped(and cleaned) my ISV three times and no changed.Renewed temp sender and fixed the problem.
Manual
Yes, I have been thinking about checking temprature sensor. According to AutoData there has to be certain resistance between connectors at certain temprature. Can I just dip it in water and check resistance? Will it not damage it? |
Make sure the throttle cable is nice and free and not over adjusted.
Check/clean throttle butterflies). And finally operation of 'closed throttle' switch. |
The temp sender for my KV engine was,about £6 from GSF.
Easy enough,job.
#10 | |
What do you mean by operation of closed throttle switch? |
