Classic Audi » Classifieds section » Parts Wanted » B3 Coupe Radiator
Old 18-07-10, 10:27 PM   #1
Couperman
Smut Meister
Couperman's Avatar
Default B3 Coupe Radiator
My brothers B3 Coupe 2.3E 5 pot 10 valve has sprung a leak. He will be checking it out tommorrow but suspects it's the rad. So, just in case does anyone have a suitable radiator.
Rod Inwood - Member 1467
Previously owned :-
Old 18-07-10, 10:36 PM   #2
Rodders try Mike (Audibits2) on eBay or his mobile
07809 222346
he is in Lockerbie, have you tried radweld ? Or checked the hoses ?
Old 18-07-10, 10:42 PM   #3
Couperman
Smut Meister
Couperman's Avatar
07809 222346
As I said Grant will be checking things out tommorrow, he believes the rad has rusted away at the bottom end so it's definitely beyond Radweld.
Previously owned :-
Old 18-07-10, 10:46 PM   #4
try these pritty cheap
http://www.northernradiators.co.uk/?...FQIB4wodRDqRmA
just put in the details
Old 19-07-10, 08:39 AM   #5
wildoliver
I have plenty of decent rads, I always weigh in the rotten ones (which are always the alloy rads) so any I have are good water tight and no rotten flanges. Even better I think I have a couple of copper ones but need to check. I'd need to know if he has the aux rad or not.
£25 to you!
The problem with these rads is almost always the same, the lower tank holding flange rots away. I once repaired one with epoxy as an emergency get me home job and it worked ok but you'd have been a brave man to have tried to run with it long term as once they start to leak they drain the entire engine/rad/header tank very quickly indeed!
wildoliver is offline   Reply With Quote
Old 19-07-10, 06:43 PM   #6
Couperman
Smut Meister
Couperman's Avatar
£25 to you!
Thanks Mate, just waiting for Grant to get in touch with the details : Part number/size etc then I'll PM you.
Previously owned :-
Old 19-07-10, 07:04 PM   #7
wildoliver
Don't need either of those mate they are all the same.
Just literally need to know if his has the aux rad or not. That's the only difference on 5 cyl rads.
Old 21-07-10, 05:53 PM   #8
Couperman
Smut Meister
Couperman's Avatar
Thanks for the info and offer but Grant has managed to repair the problem. Coupe now back on the road and being prepped for AITP.
Previously owned :-
Old 25-07-10, 12:06 PM   #9
Bob Hardon
.Have a new rad bought in error for a 1985 Audi 90CD. E.mail dimensions to rghardon43@hotmail.co.uk and if OK will arrange delivery.
Regards Bob.
Bob Hardon is offline   Reply With Quote
