Classic Audi » Community » General Chat » Fuel pressure kit-will it fit k-jet?
Old 28-03-12, 07:28 PM   #1
Default Fuel pressure kit-will it fit k-jet?
Just won this kit on Ebay and wondering,will it fit K-Jet system?I hope so?
Thanks.
KARL.
Old 28-03-12, 07:44 PM   #2
dgacampbell
dgacampbell's Avatar
Is it just for testing or leaving inline all the time??
dgacampbell is offline   Reply With Quote
Old 28-03-12, 07:52 PM   #3
Just for,testing.(fuel pump,standing pressure,ect.)
KARL.
Old 28-03-12, 08:05 PM   #4
dgacampbell
Thumbs up
Nice addition to the tool kit then, fancy one myself!!
Old 28-03-12, 08:11 PM   #5
From the diagram,can anyone tell me if it will be alright for a K-jet system.Will it fit??
Thanks.
KARL.
Old 28-03-12, 08:58 PM   #6
KARL.
Old 28-03-12, 09:57 PM   #7
There's no need for such a kit for NG - the only thing necessary for KE-jet is simple manometer which has adaptor to attach it to 4 pot injector hose, which could be fitted to both testing points on injector head, costs less and takes up way less space
Unfortunately I can't reply to main question of this thread because I haven't seen K-jet for a long time and I dunno where to measure both pressures of this system
Old 29-03-12, 06:10 AM   #8
Come on lads(+girls),what's needed to test the K-JET system?
Looks like I'll have to get off my arse and do my own research?
KARL.
Old 29-03-12, 09:09 AM   #9
Cuppatea
Cuppatea's Avatar
Not done any kjet stuff for a while now so its hard to remember for sure.
On old mk2 golf k-jets i used a sykes pikovant kit. Fitted inline with the meter head feed, with a gauge and a valve/tap. Then you can measure the system pressure and control pressure.*
with engine off you can also check to make sure the system doesnt loose pressure, good idea to check this with injectors out incase they leak from the ends.
Theres also a fuel compariter for checking injector flow rates, which can be adjusted via the screws around the metering head and the spray patterns.*
Cuppatea is offline   Reply With Quote
Old 29-03-12, 09:20 AM   #10
Cuppatea
Cuppatea's Avatar
Something like this, do the audis use a warm up regulator similar to the golfs?
I may be wrong dont shoot me down!
