Fuel pressure kit-will it fit k-jet?
Just won this kit on Ebay and wondering,will it fit K-Jet system?I hope so?:confused:
http://i702.photobucket.com/albums/w...ressurekit.jpg Thanks.:tup: |
Is it just for testing or leaving inline all the time??
Just for,testing.(fuel pump,standing pressure,ect.)
Nice addition to the tool kit then, fancy one myself!! :tup:
From the diagram,can anyone tell me if it will be alright for a K-jet system.Will it fit??
Thanks. |
Unfortunately I can't reply to main question of this thread because I haven't seen K-jet for a long time and I dunno where to measure both pressures of this system :lol: |
Come on lads(+girls),what's needed to test the K-JET system?
Looks like I'll have to get off my arse and do my own research?:( |
Not done any kjet stuff for a while now so its hard to remember for sure.
On old mk2 golf k-jets i used a sykes pikovant kit. Fitted inline with the meter head feed, with a gauge and a valve/tap. Then you can measure the system pressure and control pressure.* with engine off you can also check to make sure the system doesnt loose pressure, good idea to check this with injectors out incase they leak from the ends. Theres also a fuel compariter for checking injector flow rates, which can be adjusted via the screws around the metering head and the spray patterns.* |
Something like this, do the audis use a warm up regulator similar to the golfs? I may be wrong dont shoot me down! |
| All times are GMT. The time now is 07:42 AM. |
