Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,118 Currently Active Users: 1281 (0 members and 1281 guests) Welcome to our newest member, BuddyInons |
I have ordered a spax -60mm kit and to go with this I am going to purchase new top mounts and a full front and rear powerflex kit - problem is, there are different bushes! So which bush do I go for?
... !The car is a 1982 type 81 Audi 80 CL - the differences are... Front arm, is it alloy? or steel? And are the anti-roll bar bushes 24 or 25mm? As it is not a sport model and has the 1.6 carb engine, I would guess that the roll bar is narrower (so 24mm) and the front arm is steel? Does anyone know this? Or know where I could find out? Cheers Jon |
“Been raced and rallied”
Well as far as I can see the anti-roll bar its self is 21mm in diameter part number 811411309A
Cars with power steering from 1982 are 22mm and a different sort, there is a connecting link arm (sort of drop arm from the bar to the wish bone) so I would go out and measuer yours just to see what you have.. And yes the front arms are steel.. ..
Almost thought this was going to be a Keeley moment
![]() But ive promised Panda to be good for a while ![]()
Thanks...
Jon |
my 1986 80CL roll bar is 21mm, my 86 80 Sport roll bar is 22mm WITHOUT the drop links.
I have a 1986 90 roll bar which has drop links and is 24mm I think, but definitely more than 22mm. Front arm is steel (have a quick look and it will look like it is made from folded steel sheet, which it is. I would go for poly bushes for the front wishbones and rear trailing arm but go for standard roll bar bushes. Are Powerflex back in business, they had a fire in late November 2009????? Don't forget bump stops too, they need to be shorter (poly or cut down standard ones) |
They have had a fire - but luckily my local Larkspeed had some in stock!
Thanks for all the help - ill get some proper pictures on here soon... Jon |
| Bushes | pimpdriver | Parts Wanted | 42 | 28-04-10 03:25 PM |
| superflex bushes | Acidburn | Suspension & Brakes | 7 | 24-12-09 01:15 PM |
| fitting bushes etc | pimpdriver | Suspension & Brakes | 2 | 10-06-09 11:46 AM |
| Audi 100 shocks and bushes... | Lankytim | General Chat | 2 | 26-12-08 06:20 PM |
