Classic Audi » Classifieds section » Parts Wanted » 4 cyl carb manifold
Old 14-08-09, 10:18 PM   #1
Default 4 cyl carb manifold
Anybody got a carb manifold off an 80CL or GL (1.6 or 1.8)??? 4 cylinder please........
Old 14-08-09, 10:38 PM   #2
Puglife
==>PUGSPORT!<==
Puglife's Avatar
Same as VW engines iirc.... think i scrapped both my carb manifolds.... will double check for you.
Old 16-08-09, 07:25 PM   #3
Audi Derek
“Been raced and rallied”
Audi Derek's Avatar
Yes I do
Is it hydraulic tappets or solids as one of the manifolds has an air feed on it..
Old 16-08-09, 08:36 PM   #4
Hydraulic. Which is yours for? WHat I want to do is to swap my 1.6 DT engine for a 1.8DZ engine, but keep it on the Weber carb (simpler for me!).
I could swap the existing manifold over onto the DZ head (and block up the injector holes with pennies), but I'd rather minimize the time the car is out of action.
1.6 with 75 bhp to 1.8 should get me 90-95bhp probably (1.8 from the GL is 90bhp, but the DZ has a better head I think). Not much more power, but should make it more useful.
ALso got better front brakes to go on, to make it stop better.
Old 16-08-09, 09:07 PM   #5
Audi Derek
Audi Derek's Avatar
I will try and take a pic of it tomorrow and show you then you can make your own mind up about it..
I do have both of them..
Old 16-08-09, 09:16 PM   #6
Great!
I am in no hurry, just whenever is convenient. Whereabouts in Zummerzet are you?
Old 16-08-09, 09:24 PM   #7
Audi Derek
Audi Derek's Avatar
Bridgwater,..
Old 16-08-09, 09:28 PM   #8
Will be passing through (well M5 at least) sometime in August, possibly early September.
Old 17-08-09, 11:05 AM   #9
And what are u going to do with with bigger intake paths - are u shure that carb manifold will close it?
Old 17-08-09, 12:21 PM   #10
Pretty sure about it.
My mate fitted a Golf GTI head onto his 1.8 carb engine (presumably same as the 1.8GL engine), and fitted his carb manifold to it.
I think it is the valves that are bigger, not necessarily the inlet holes.
Carb and jetting Hloni Engine 2 27-01-10 09:08 PM
WN carb and intake manifold. 4v6 Parts Wanted 0 19-01-09 09:55 PM
WN carb inlet manifold knobstar Parts Wanted 5 29-12-08 04:46 PM
Carb mount betmasterx Engine 2 22-04-08 06:16 PM
