Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,156 Currently Active Users: 16073 (0 members and 16073 guests) Welcome to our newest member, BuddyInons |
Anybody got a carb manifold off an 80CL or GL (1.6 or 1.8)??? 4 cylinder please........
==>PUGSPORT!<==
Same as VW engines iirc.... think i scrapped both my carb manifolds.... will double check for you.
#3 | |
“Been raced and rallied”
Is it hydraulic tappets or solids as one of the manifolds has an air feed on it..
Hydraulic. Which is yours for? WHat I want to do is to swap my 1.6 DT engine for a 1.8DZ engine, but keep it on the Weber carb (simpler for me!).
I could swap the existing manifold over onto the DZ head (and block up the injector holes with pennies), but I'd rather minimize the time the car is out of action. 1.6 with 75 bhp to 1.8 should get me 90-95bhp probably (1.8 from the GL is 90bhp, but the DZ has a better head I think). Not much more power, but should make it more useful. ALso got better front brakes to go on, to make it stop better. |
I will try and take a pic of it tomorrow and show you then you can make your own mind up about it..
I do have both of them..
Great!
I am in no hurry, just whenever is convenient. Whereabouts in Zummerzet are you? |
Bridgwater,..
Will be passing through (well M5 at least) sometime in August, possibly early September.
#9 | |
#10 | |
My mate fitted a Golf GTI head onto his 1.8 carb engine (presumably same as the 1.8GL engine), and fitted his carb manifold to it. I think it is the valves that are bigger, not necessarily the inlet holes. |
| Carb and jetting | Hloni | Engine | 2 | 27-01-10 09:08 PM |
| WN carb and intake manifold. | 4v6 | Parts Wanted | 0 | 19-01-09 09:55 PM |
| WN carb inlet manifold | knobstar | Parts Wanted | 5 | 29-12-08 04:46 PM |
| Carb mount | betmasterx | Engine | 2 | 22-04-08 06:16 PM |
