Classic Audi » Technical » Mech/Tech » Engine » ABY AND ADU.Difference??
Old 05-03-10, 10:08 PM   #1
Default ABY AND ADU.Difference??
What is the difference,between the two engine set ups?
How can you get more HP,out of an ABY?
Thanks,Karl.
Old 05-03-10, 10:20 PM   #2
Thanks,Karl.
There is, in raw form, hardly any difference...
Old 05-03-10, 10:23 PM   #3
what is an ABY? And ADU?
NF is the one to have!!! 59bhp/litre!!!!
Old 05-03-10, 10:24 PM   #4
NorrS2
NorrS2's Avatar
Thanks,Karl.
I had ABY S2 Avant for 7 years, but my knowledge is limited, however, I picked up a bit from the S2 Forum (great bunch), so, if you've serious quesions, that's the place to ask questions.
I have picked up a little bit (I think):-
ABY absolute limit with standard Turbo is 300 bhp.
RS2 has bigger Turbo, Injectors, different Exhaust Manifold etc etc:-
In summary Biggyin, it's easy to make an ABY into RS2 spec if you've got the money and inclination! But ABY limit is 300bhp without some surgery.
Thought about myself many times!!!!!
B5 RS4
88 Pearl White MB Ur quattro
NorrS2 is offline   Reply With Quote
Old 05-03-10, 10:27 PM   #5
NorrS2
NorrS2's Avatar
ADU is the RS2 Engine, ABY is the 230 BHP "overboost" S2 Engine.
B5 RS4
Old 05-03-10, 10:29 PM   #6
SteveT63
SteveT63's Avatar
ABY is S2 ADU is RS2.
Same engine apart from a few subtle mods like the Turbo, Injectors, Inlet, Exhaust Cam, ECU and some Porsche badges.!!......
T85 1985 90quattro I5 20vT
T81 1983 80 Sport Red
T81 1983 80 Sport Silver
Old 05-03-10, 10:33 PM   #7
Hmmm... Sort of...
The ABY limit on standard turbo (K24) will make circa 300bhp, but with bigger Turbo, injectors, intercooler etc will make up to 400bhp+, I've been in a 420bhp one, with standard bottom end.... BUT.... And it's a big but, the bhp isn't really the issue, torque is, for the engine will bend it's rods at this sort of power if the torque isn't controlled. So conventional wisdom rightly says circa 350bhp on standard rods... Get Scat rods and you're away... The old girls will take the bigger power without major issue.
Old 05-03-10, 10:34 PM   #8
NF.
Or DT!!!
Old 05-03-10, 10:37 PM   #9
So it,s just some slight(expensive)tuning.They are the same cc?
Might have alook over on the S2 site.
Thanks,for your replies.
Old 05-03-10, 10:39 PM   #10
Yes, same cc and internally almost identical to all other 20v's...
