Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Which Bushes?..
Old 26-01-10, 06:46 PM   #1
Jon_G
Jon_G's Avatar
Default Which Bushes?..
I have ordered a spax -60mm kit and to go with this I am going to purchase new top mounts and a full front and rear powerflex kit - problem is, there are different bushes! So which bush do I go for? ... !
The car is a 1982 type 81 Audi 80 CL - the differences are...
Front arm, is it alloy? or steel?
And are the anti-roll bar bushes 24 or 25mm?
As it is not a sport model and has the 1.6 carb engine, I would guess that the roll bar is narrower (so 24mm) and the front arm is steel?
Does anyone know this? Or know where I could find out?
Cheers
Jon
Jon_G is offline   Reply With Quote
Old 26-01-10, 09:07 PM   #2
Audi Derek
“Been raced and rallied”
Audi Derek's Avatar
Well as far as I can see the anti-roll bar its self is 21mm in diameter part number 811411309A
Cars with power steering from 1982 are 22mm and a different sort, there is a connecting link arm (sort of drop arm from the bar to the wish bone) so I would go out and measuer yours just to see what you have..
And yes the front arms are steel..
Old 26-01-10, 11:14 PM   #3
Almost thought this was going to be a Keeley moment
But ive promised Panda to be good for a while
Old 02-02-10, 06:01 PM   #4
Gaz
Gaz's Avatar
Old 03-02-10, 08:34 AM   #5
Jon_G
Jon_G's Avatar
Thanks...
Jon
Old 03-02-10, 11:26 AM   #6
my 1986 80CL roll bar is 21mm, my 86 80 Sport roll bar is 22mm WITHOUT the drop links.
I have a 1986 90 roll bar which has drop links and is 24mm I think, but definitely more than 22mm.
Front arm is steel (have a quick look and it will look like it is made from folded steel sheet, which it is.
I would go for poly bushes for the front wishbones and rear trailing arm but go for standard roll bar bushes.
Are Powerflex back in business, they had a fire in late November 2009?????
Don't forget bump stops too, they need to be shorter (poly or cut down standard ones)
Old 06-02-10, 09:12 AM   #7
Jon_G
Jon_G's Avatar
They have had a fire - but luckily my local Larkspeed had some in stock!
Thanks for all the help - ill get some proper pictures on here soon...
Jon
Bushes pimpdriver Parts Wanted 42 28-04-10 03:25 PM
superflex bushes Acidburn Suspension & Brakes 7 24-12-09 01:15 PM
fitting bushes etc pimpdriver Suspension & Brakes 2 10-06-09 11:46 AM
Audi 100 shocks and bushes... Lankytim General Chat 2 26-12-08 06:20 PM
