Classic Audi » Technical » Mech/Tech » Electrical problems » Indicators that don't!
Old 15-07-09, 05:51 PM   #1
nickob
Default Indicators that don't!
Hi,Can anyone tell me where the flasher unit is on a 1986 Coupe Quattro? My indicators stopped flashing about a week ago but I can't find the flasher unit.Is it behind the dash as there is a ticking noise from there if you turn the hazards on and off. Thanks for your help in advance, Nick
nickob is offline   Reply With Quote
Old 15-07-09, 07:29 PM   #2
stuartmmcfc
Now I could be wrong, but on my ur its behind the dash.
unscrew the 4 screws which hold the frame onto the "pod" and then pull frame forward.
it may be easier to pull off one set of connectors from switches on one side of the frame so you can swing it out of the way.
pod should lift away then and flasher unit (silver cube about 25mm square) is attached to a lug at back of display.
i always take the steering wheel of as well to improve access.
Old 15-07-09, 07:53 PM   #3
The relay is on passingers side in the birds nest wiring under the glovebox!!!!!!!
Old 15-07-09, 08:11 PM   #4
stuartmmcfc
now I'm prepared to say "I dont really have a clue", but while there may be a relay under the glove box, I'm pretty sure the thing i've had to take off when i was messing with the dash was the flasher unit- ie the thing that makes the clicking noise.
there again very worth while checking relays behind glove box out.
ps Amanda, do you see jay much? just that ian may have a parcel for me and hes seeing him soon.
Old 15-07-09, 08:26 PM   #5
Hmmm and I am no mechanic either Which Ian do you mean?
Old 15-07-09, 09:12 PM   #6
I'm seeing Jay this weekend before dragging my arse to Nottingham on Sunday so if you need anything delivering now is the time to shout up
Old 15-07-09, 09:31 PM   #7
steveb
steveb's Avatar
Flasher unit is behind the dash (rev counter / speedo ) clipped to the back of the instrument cluster as stuartmmcfc said
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 16-07-09, 06:39 AM   #8
stuartmmcfc
that would have been handy, but Simmos not going to puglifes (jay) until Tuesday/Wednesday
not the end of the world though
Old 17-07-09, 12:11 AM   #9
5potnoodle
OCD member
5potnoodle's Avatar
Do your hazard flashers work ok? The hazard switch only recreationtes what the indicator stalk switch does but both sides at once. If the indicators all flash and the relay is clicking it's not the relay, it's the stalk.
Current:
99 Subaru Forester S-Turbo Auto - interesting... but it's not a quattro
91 Reliant Scimitar SST 1400 - no.39 of 42... something for the weekend
Previous:
Two consecutive 1989 Audi 200 Quattro Turbo Avant, 1B
1990 Audi 100 SE Avant, NF
1986 Audi 100 CD Avant, KU
1987 VW Passat GL5E Estate, JS
"Honorary" triple member of the 200,000+ Club
Audi 200 in the UK (legacy website)
Classic Audi member no: 258
5potnoodle is offline   Reply With Quote
Old 17-07-09, 08:54 AM   #10
I'll be doing the same run the following weekend to could still do a pick and drop for you no probs
Just let me know
Indicators stuck on Incredibelly Electrical problems 3 07-01-10 03:48 PM
audi 80 cab headlights,fogs,indicators FS/swap m15 vw Parts For Sale 0 16-10-08 12:57 PM
B2 80 saloon pre facelift clear indicators?? geordie1980 Parts Wanted 0 18-03-08 06:41 PM
