Classic Audi » Technical » Mech/Tech » Electrical problems » Headlight problem
Old 27-06-09, 01:28 AM   #1
stephen2320
stephen2320's Avatar
Default Headlight problem
Hello all, i have just aqquired my dream car the audi coupe 2.3 10v 5 cylinder 1993 on a L. mint condition, except, the headlights work fine and so does the stork as far as i know but when i use the headlights they all work fine until i try to use main beam, they work when flashing/pulling stork towards but when i try and put main beam on by pushing away the dipped headlights go out and only the side lights come on then when pulling the stork back into position dipped headlights return? any help on this would be much appreciated. thanks stephen.
stephen2320 is offline   Reply With Quote
Old 27-06-09, 08:35 AM   #2
andy quattro
andy quattro's Avatar
That sounds like there is a problem within the storks the lighting side of the storks are prone to failing i have change a few.
AUDI QUATTRO WR (85)
AUDI 80 QUATTRO (84)
AUDI 90 20V QUATTRO (89) EX PRESS CAR(sold)
AUDI 100 AVANT (88)
AUDI A4 2.5 TDI QUATTRO(2001)
VW POLO 1.9D(97)
andy quattro is offline   Reply With Quote
Old 27-06-09, 08:38 AM   #3
Yes I would agree also, just replaced one on the red mb
Old 27-06-09, 02:41 PM   #4
stephen2320
thanks, how much do the storks cost, where from and how do i go about replacing it? thanks for your help i'm still quite new to this!
Old 28-06-09, 03:07 PM   #5
andy quattro
You can get second hand storks from most breakers for around £15 to £20 fitting quite easy bit harder if your car is fitted airbag because the steering wheel has to come off?
AUDI 100 AVANT (88)
VW POLO 1.9D(97)
Anybody else get this problem? stuartmmcfc General Chat 1 05-11-09 06:44 PM
Indicator Problem Audi6r Electrical problems 1 27-03-09 12:54 AM
Not a problem as such... Daveymaclad Electrical problems 2 20-03-09 02:50 PM
