Classic Audi » Classifieds section » Parts For Sale » Garage clearout!
Old 10-04-09, 12:39 PM   #1
4v6
Default Garage clearout!
Ok, ive a feeling i might regret this......as ive now got a garage full of surplus used bits, i need A) the room and B) the money to continue funding Quasi, so ive amassed a collection of parts that wont get used and may as well go to you guys who need them.
I have NO idea on what these bits are worth, so please dont go pulling my pants down and smacking my bottom on the price!
Ill list them with the part numbers on so you can compare with your own needs.
Right, here goes.
1X wastegate and actuator assembly with flexipipe- 1B engine- 035 145 703 A
1X wastegate and actuator assembly with felxipipe -WR engine- 035 145 705 T
1X k26 Turbo (will need renovating but good for spares- 035 145 703 L
1x k26 turbo as above-but part number- 035 145 703 E
1X Exhaust manifold has been welded not cracked anywhere else- 035 128 591 CE
1X Boost hose (WR) 035 145 746 B
1X WR injector cooling fan- 035 959 175 B
1X warm up regulator 034 133 403 A ( bosch 0438 140 157)
1X good condition KV stock Camshaft.
1X good condition JS stock camshaft.
1X WR camshaft- has slight nick on front oil seal surface.
1X set of 4 hockey sticks.
part numbers: Uppers 2X 811 853 836 D -------- 1X 811 853 835 D
Lowers: 1 X 811 853 841 D 1 X 811 853 842 D
1X genuine audi ignition leads (used) with flat type cable arranger and removable slide out top section for access.
1X intake manifold (WR) with cold start injector, throttle body and aux air valve fitted.
1X 1B intake manifold bare, i do have the throttle body to go with it if needed.
Various braided injection hoses- most have no loose strands free and are in good overall condition.
1X WR bottom end complete- no head as was cracked will require overhaul is my feeling and although it didnt knock or smoke itd be unwise to try using it as is.
Any funds gained from this lot go straight into Quasi.
I was going to do a full rebuild on the 1B engine but itll have to be a special short block build some time later down the line, hence some of its parts are listed here too.
Would sell it all as a job lot ( less hassle!) or individually. Cheers!
Having a clearout! 4v6 Parts For Sale 2 12-01-10 09:41 PM
Big List Clearout Puglife Parts For Sale 29 26-11-09 06:58 PM
Yet more clearout parts Puglife Parts For Sale 0 25-08-09 04:27 PM
type 85 clearout Puglife Parts For Sale 0 24-06-09 12:31 AM
got bills to pay lol big clearout sam Parts For Sale 11 22-06-09 04:59 PM
