Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Rear Strut Top Mount Access
Old 26-02-24, 11:55 AM   #1
hulkb3
Thumbs up Rear Strut Top Mount Access
Afternoon all.
Query on b3 coupe rear suspension, Im sure this is covered previously etc but just after a quick reminder - before i go ripping out the rear trim and carpets this evening, is there a slot to access the strut top from inside the car? Seem to recall there is if i remove the side bolster but may be confusing myself with saloons...
TIA
hulkb3 is offline   Reply With Quote
Old 27-02-24, 07:48 AM   #2
tractor Dave
If it's the same as b4 you need to remove the trim panel either side above the strut housing. Take care as the plastic clips on the trim break easily.
Old 27-02-24, 11:09 AM   #3
Duffy3074
It’s obvious and easy enough once you’re in there
Old 28-02-24, 06:22 PM   #4
hulkb3
Thanks for coming back to me chaps - job for weekend.
