Members: 42,809 | Total Threads: 40,081 | Total Posts: 471,010 Currently Active Users: 606 (1 members and 605 guests) Welcome to our newest member, AndrewLoado |
![]() Hi. I did see once an article showing how to remove the door card inc handle etc. I need to see why the travel on my external door lever has increased making it difficult to open
Anyone have such info or direct me to the site |
![]() I don't know the article, but it's pretty straightforward.
Remove all the screws from around the door pocket, plus one that is in the pocket divider (accessed by putting a pozi screwdriver through the carpeted section. Remove the cover in the middle of the "mirror" triangle and the screw behind to reveal another screw holding a tab at the top of the door card. Similarly, pop the cover behind the internal handle, remove screw & backplate, 2 screws in the underside of the door pull. If it's the driver's side, pop the connector for the mirror control. Unscrew the locking knob on top. Then it's 2/3 poppers down each side, lift it out of the window slot and Robert's your mothers brother ![]() Regarding the handle travel, I also experienced this and found the handle casting to be cracked and required a replacement. Hope this helps & good luck ![]()
1985 WR quattro 2010 A6 3.0Tdi Allroad 2010 A3 1.4 tfsi Sport - Sold but still in the family 1984 80 Quattro - Sold many moons ago 1981 Coupe GT - Sold to buy above Last edited by urquattr085; 12-09-19 at 08:39 PM. Reason: I can't spell |
![]() Perfect thanks. Will get a new handle ready and get to work
![]() ![]() Be careful of the plastic links between the handle and lock mechanisms, they can be a bit brittle.
![]() Understood. Thanks for the heads up
![]() Those instructions are spot on-i only mention that to remove the inner grab handle you need to rotate it about 60 degrees clockwise to line up the slots with the retainers-you'll see what i mean when you do it...
also, anyone have a spare one of these "pop the cover behind the internal handle" and is at the meet on Sunday? I have £2 for you if you do! |
#7 | |
![]() Quote:
![]() ![]() ![]() Always happy to be corrected though ![]()
![]() Finally got around to it last night. Door card all off, tip on handle useful. Handle to be replaced. Before I get forceful with the rods linked to the handle mechanism, do they pull out of the plastic cam and metal link?
Lever gave up the ghost as I went to open door to strip the card so new handle it is. |
![]() https://audi.7zap.com/en/rdw/audi+qu...6/8/837-78000/
Item 9 is a push fit into 29 Item 36 needs to be rotated to unclip it from item 8. Item 8 can then be pulled out if the small lever on the handle Remove screws 17 & 18 and you're there ![]() Not much room for big hands like mine &you will lose some skin on those panel edges ![]() ![]() ![]() Good luck with it
![]() Perfect explanation thanks. Will crack on at the weekend ready for the new handle..... when it arrives.
