Classic Audi » Technical » Mech/Tech » Interior » Heater flap foam ?
Old 02-12-18, 06:16 PM   #1
Default Heater flap foam ?
I have the matrix to do on my tdi dog wagon and I'm going to replace the heater flap foam at the same time...…..is it this type of stuff that I need? https://www.ebay.co.uk/itm/3mm-Bag-M...Seqw:rk:2:pf:0
Old 02-12-18, 07:53 PM   #2
Duffy3074
Neoprene Foam Sheet Self Adhesive - Sound Proofing, Insulation 1m x 900mm x 2mm https://rover.ebay.com/rover/0/0/0?m...2F264049619927
That’s too soft, I used this on mine
Duffy3074 is online now   Reply With Quote
Old 02-12-18, 08:04 PM   #3
Ok cheers Duffy...….if you don't mind me asking, why is the 3mm stuff too soft?
Old 02-12-18, 08:10 PM   #4
Duffy3074
It’s made of a much softer material, you use scrim foam on the door cards for example. It’ll flex and rip fairly quickly methinks.
Old 02-12-18, 08:12 PM   #5
.....ok, will get your stuff.
Old 02-12-18, 10:00 PM   #6
KB_Yorks
One thing maybe to consider is that within the heater matrix it will get very hot, if the self adhesive glue does not work well in hot temperatures then it may unstick.
The first time I did the heater matrix flaps on my MK 2 GTI I used self adhesive foam but a few months later I found the foam been blown up to my vents and so it didnt stay stuck.
The next time i attempted repair but on my B3 CQ I used non self adheisive material but used M3 double sided tape with good heat resistent properties (stay stuck at high temperatues). Not had any issues as of yet with this.
KB_Yorks is offline   Reply With Quote
Old 03-12-18, 05:13 AM   #7
Old 05-12-18, 09:12 AM   #8
Duffy3074
That’s a fair point, my car doesn’t see a winter road so the foam’s only seeing fresh air.
