Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,156 Currently Active Users: 14658 (1 members and 14657 guests) Welcome to our newest member, BuddyInons |
The cigarrette lighter socket in my B3 90 20v has had it and I need to replace it. Trouble is that I can't see how it comes out of the centre console without removing said console and the Haynes manual doesn't help much.
![]() Is there an easy way to get at the ciggy lighter because when we're touring, I use that socket to power the phone charger, Sat Nav, car fridge, etc. In fact everything except the ciggy lighter! |
Aero Advocate
Is the lighter inside the pull out ashtray? If so pull the ashtray out as far as you can, it should reveal an 8mm nut you can undo. This will let u take out the black plastic surround and lighter socket. The whole ashtray can be removed by taking off the heater knobs, undoing the 2 phillips screws, taking off the faceplate revealing 2 more phillips screws underneath.
If you have the 3 supplementary gauges the lighter socket is pushed into the floor console? In which case 3 8mm bolts hold it down, one by the handbrake and 2 under the rear ashtray (pulls out)
#3 | |
Aero Advocate
yes, holding the back! The ones under the heater controls just hold the front ![]() Its been a while....!
Yes, the lighter is in the ashtray directly beneath the heater controls.
Thanks, chaps. I'll take a look when it stops raining. Last edited by SwallownAmazon; 23-03-18 at 10:04 AM. Reason: Omission |
Got it out exactly as described although that set screw was a bugger to get out of its slot even with jewellers' fine nosed pliers.
New one awaited from the Bay as I type. Thanks for the guidance. |
Aero Advocate
