Classic Audi » Classifieds section » Parts Wanted » 80 Sport Fuel Metering Head Needed, Same as Mk1 GTI???
Old 23-02-09, 06:26 PM   #1
rado-steve
rado-steve's Avatar
Default 80 Sport Fuel Metering Head Needed, Same as Mk1 GTI???
Hi All,
Hoping somebody can help!
My 80 sport is poorly sick and needs a new Fuel Metering Head! Am I right in thinking they are the same as a Mk1 Golf GTI uses???
Anyway, the Bosch Part Number is: 438.120.189
Also need the fuel pipe that runs undernetah the car as someone has replced mine with rubber fuel hose
Cheers Y'all
Steve
rado-steve is offline   Reply With Quote
Old 23-02-09, 07:36 PM   #2
vag80
vag80's Avatar
I think they are the same, or you can use one from a b3 80 1.8E with DZ engine as they are the same
engine and bolt stright in not 100% sure if golf gti has the same fixings
Old 23-02-09, 08:23 PM   #3
ChrisG
ChrisG's Avatar
http://hosesolutions.org.uk/catalog/index.php?cPath=18
http://www.demon-tweeks.co.uk/produc...T&pcode=PSIS46
http://www.racehoseshop.com/
these were listed on the Club Audi site as a suitable place to look for pipe/hose items, hope this is of use !
Old 23-02-09, 11:26 PM   #4
rado-steve
rado-steve's Avatar
Cheers, What does one of those look like?? Pic..Sorry for thickness
Old 24-02-09, 08:54 PM   #5
vag80
vag80's Avatar
Hi steve if you go to my album and look at my 80 thats a b3 shape and the engine is a
DZ 1800 the same as in a b2 sport
Old 26-02-09, 07:17 PM   #6
rado-steve
rado-steve's Avatar
Anyone Know if a Mk1/2 GTI one will work???? Same size 1.8 8v Engine
Old 26-02-09, 07:59 PM   #7
Puglife
==>PUGSPORT!<==
Puglife's Avatar
will check at weekend as i have a few metering heads... essentially all the same as the capacity will relate to fuel needed.
Old 27-02-09, 06:45 PM   #8
rado-steve
rado-steve's Avatar
Ta Muchley!
Old 28-02-09, 03:09 PM   #9
BigT80
Hi All,
Cheers Y'all
Steve
Yo! Looks like you could be sorted, but if you get toally stuck I've got one from my 1.8GT Coupe (DZ 049842) that got too rusty and had to go. It was working fine when removed a few months ago, although the car was high mileage (236k) it ran fine. It's sat here, so no probs either way. Cheers.
BigT80 is offline   Reply With Quote
Old 28-02-09, 04:01 PM   #10
DZ engine is the same as on mk2 GTI 8v golf, only in vw's this engine was with code, if I remember correctly, EV - different because there is different intake manifold
Fuel metering head/distributor needed for 2144 80 quattro. naptik Parts Wanted 4 04-02-10 08:45 PM
wanted metering head kv stoop44rio Parts Wanted 21 23-12-09 08:11 AM
type 43 metering head for fuel injection unit jack1 Parts Wanted 10 15-11-09 09:13 AM
100 Turbo Fuel Metering Head Engine code MC Rodders Parts Wanted 5 10-05-08 12:52 PM
Jetronic Fuel Metering Head / Air Flow Meter randall977 Parts Wanted 5 17-12-07 04:26 PM
