Classic Audi » Technical » Mech/Tech » Engine » Dropping fault codes
Old 17-11-16, 10:11 PM   #1
Bandycoot
Default Dropping fault codes
Whats the best way of dropping the fault codes on my b3 90? I've got a Ross tech interface from when I had an S8 and I wanted to use an adapter but speaking to Ross tech it's not compatible.
Bandycoot is offline   Reply With Quote
Old 17-11-16, 10:26 PM   #2
Sandro
Sandro's Avatar
Probably fuse method
http://www.sjmautotechnik.com/troubl...g/100ecuf.html
Old 18-11-16, 07:55 AM   #3
the later 4 plug ecu version works with vcds.
1991 90 quattro
Old 18-11-16, 01:05 PM   #4
Bandycoot
Apparently, as my diagnostic plugs are three wire and not four, the adaptor for my interface won't work. That's according to the boffins at Ross tech.
Old 18-11-16, 01:39 PM   #5
Bandycoot
