Classic Audi » Classifieds section » Parts Wanted » Air flow meter (abk)
Old 28-08-16, 10:38 AM   #1
vag2109
Default Air flow meter (abk)
Hi,
does anyone have an air flow meter for an abk engine for sale?
Cheers
vag2109 is offline   Reply With Quote
Old 29-08-16, 06:45 AM   #2
DanielGT500
DanielGT500's Avatar
Originally Posted by vag2109 View Post
Hi,
Cheers
Out of interest... Does yours suffer from juddering and losing power?
DanielGT500 is offline   Reply With Quote
Old 29-08-16, 07:22 AM   #3
vag2109
Hi Dan,
yes and coughing and spluttering back firing, smells of unburnt fuel, etc. Do you have the same problem?
Old 29-08-16, 07:40 AM   #4
DanielGT500
Hi Dan,
Yes and I have replaced the Relay 30 and it seems to have sorted the problem although the only test was to drive to AITP8, haven't done much around town. I'd recommend replacing that first as it is about £10 for a new one off eBay (make is Meyle). This is to be found under the cover below the steering wheel. This seems to be a common problem with ABK. If this doesn't sort the problem, then go on to the more expensive repairs such as the air flow meter.
Old 29-08-16, 07:49 AM   #5
vag2109
Hi Dan,
thanks for the tip, but I`ve already replaced relay 30, and fuel pump relay, blue temp sensor,rotor arm , dizzy cap, plugs and leads
