Classic Audi » Technical » Mech/Tech » Engine » timing marks don't line up
Old 12-08-15, 03:18 PM   #1
Flipman
Flipman's Avatar
Unhappy timing marks don't line up
Hello!
I'm about to remove cylinder head on my urq -83 10v wr.
I would want to get engine to TDC before that.
But the timing marks don't line up as they should.
What could be wrong?
/Regards Emil
pics:
Flipman is offline   Reply With Quote
Old 12-08-15, 04:05 PM   #2
wopitop
Timing mark on the dizzy is just an rough guide, you have to set you timing while the engine is runnig. The timing on your crack and on your cam is spot on.
wopitop is offline   Reply With Quote
Old 12-08-15, 04:05 PM   #3
ian20v
ian20v's Avatar
I just did head job on 5 pot turbo kg,i used audi crank locking tool to get approx. tdc had to set the timing when i'd put back together as was slightly out,yours looks ok for head removal.Mine is starting first turn of the key
1987 audi 200 Quattro saloon sorned,few bits to do yet.
1987 Audi 200 quattro avant sorned,getting rebuilt
Daily Toyota Hilux 1999 2.4td double cab
VW caddy van 1.9tdi 2010
Old 12-08-15, 04:16 PM   #4
Hanuman
Hanuman's Avatar
Looks about right. The large embedded 0 on the flywheel is bisected by the casing. The paint marks are irrelevant.
When putting it all back together, you should have
0 mark bisected by the casing.
Cam sprocket mark approximately level with head upper face ( in the window)
The dizzy arm pointing at a very defined groove on the cap mounting face.
Old 12-08-15, 04:51 PM   #5
Flipman
Flipman's Avatar
Okey!
Thanks a lot!
I'm just waiting for crank locking tool I have ordered.
Old 12-08-15, 06:19 PM   #6
4v6
Possible reason for marks not lining up is when the heads been skimmed as it alters the distance the belt would normally be running over so it effectively[ moves the timing a small amount.
Old 12-08-15, 07:32 PM   #7
Groundhog
No you don't, the timing is determined by the flywheel senders and ECU, there is no 'timing' to set.
Old 12-08-15, 08:50 PM   #8
jimh
That's fine.
Flywheel is spot on.
Cam wheel is correct - it can only be multiples of a whole tooth out, so it's obvious when it's wrong.
You could adjust the distributor body a little when you're done, but it won't have any effect on the timing.
The only time this would be an issue was if the distributor was out of position far enough that the rotor arm and contact points in the cap don't line up enough on full boost (full timing retard and the reason for the extra wide rotor arm tip). You'd know that as you'd get a misfire on boost.
If it was really far enough out, it would not be in the hall sensor window and would not start.
The timing is set by the ECU depending on the flywheel sensors with adjustment for load/boost, rpm & inlet air temp. The distributor only has to be roughly in position such that the hall sensor window is in range and the rotor arm & distributor contact points line up over the whole range of timing set by the ECU.
jimh is offline   Reply With Quote
Old 15-08-15, 09:05 AM   #9
Flipman
Flipman's Avatar
Ok ..
I have released the timing belt, and removed away all the stuff so I can remove
the cylinder head.
I just wonder what kind of bolt design is the cylinder head bolts?
I thought it was the allen / torx bolts, etc ...
Old 15-08-15, 09:20 AM   #10
wopitop
It will be a 12 point socket. I think you have the M12, you can buy it at the most tool shops. Make sure it is the longer version, a short one might foul your head.
