Classic Audi » Technical » Mech/Tech » Engine » engine swap ?
Old 30-12-14, 04:26 PM   #1
Flying Frank
Flying Frank's Avatar
Default engine swap ?
Anyone care to enlighten me on possible problems and requirements when changing a cars complete engine from a carb one up to a complete injected engine. Assume car body shell/model/year are identical.
Thanks.
Old 30-12-14, 05:52 PM   #2
Val
Val's Avatar
If you could be more precise mentioning at least chassis you are working with?
Val is offline   Reply With Quote
Old 30-12-14, 06:57 PM   #3
Flying Frank
Ok, B2, carb to injection.
Old 30-12-14, 07:01 PM   #4
Val
Val's Avatar
Air filter bracket, fuel pump assembly under floor and reroute fuel lines. Nothing impossible.
Old 30-12-14, 07:08 PM   #5
Flying Frank
ok thanks, I thought I read somewhere something about needing a special fuel tank as well or was I mistaken ? Special in as much as the one from the "injected" car?
Old 30-12-14, 07:18 PM   #6
Val
Val's Avatar
Nothing interesting in etka online catalogue? Haven't seen carb fuel tank in my life. Difference should be only fwd vs quattro tank.
Old 30-12-14, 09:58 PM   #7
Flying Frank
Ok, many thanks for that.
Old 30-12-14, 10:27 PM   #8
jamiecoysh
jamiecoysh's Avatar
fuel tanks are different don't ask why just know they are when I had to source a replacement for myself. Probably to do with the size of the hose that runs from the tank to the injection pump is quite fat and the carb model is one size diameter all the way through as the pump is driven of the engine on the carb models
Old 01-01-15, 07:35 PM   #9
Addicted
Carb and injection tanks are different. I had to have a large bore outlet brazed in when I did my engine swap
1985 Type 81 2 door 2.8 V6
1983 Golf GTI track weapon
1977 Scirocco G60
1968 Sand Rail
Old 01-01-15, 08:36 PM   #10
Flying Frank
Thanks , that was what I'd read somewhere, but glad for the confirmation. Cheers!!
