Classic Audi » Technical » Mech/Tech » Engine » starting problem on cq
Old 27-04-14, 02:11 PM   #1
andya
andya's Avatar
Default starting problem on cq
I have a problem that has been steadily getting worse for the last 2 weeks or so. I will fire up in the morning, 1st time, straight away, I drive say to a petrol station, fill up, restart, it wont! I leave it 5-10 mins, turn the key, hey presto it fires straight up. Today I drove down to the coast, stopped, parked up, switched it off. Went to fire her up, nothing. Waited 10 mins, turned the key, it fired straight up.
Any ideas? When it fails, it comes on, but immediately the revs drop, and it stalls.
1985 Coupe Quattro
1986 Coupe 1.8 weber carb
1987 Coupe 2.2 GT
Old 27-04-14, 03:11 PM   #2
moonwatcher
moonwatcher's Avatar
I had a similar situation, try the cold start relay probably sticking, remove and re-insert
Coupe Quattro 1985
Old 27-04-14, 04:55 PM   #3
Daveymaclad
Daveymaclad's Avatar
I had a hot start problem with my UR when I first got it. Turned out to be something to do with the fuel pump if I recall (back before I was active in getting oily myself!)
2008 RS6 avant
SOLD 1988 UR Quattro
Old 27-04-14, 06:36 PM   #4
andya
andya's Avatar
Thanks dave, moonwatcher and ken, at least I've got things to look at.
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 27-04-14, 06:52 PM   #5
andya
andya's Avatar
Whereabouts is the relay? Not listed in the haynes or bentley book? Many thanks. Andy
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 27-04-14, 06:54 PM   #6
jamiecoysh
jamiecoysh's Avatar
had the same problem on my 2.3e and it turned out to be metering head fault
Old 27-04-14, 07:37 PM   #7
Question Could be?
Had a similar problem,turned out to be fuel pump relay.
When it cut out,I'd have to wait about 15 minutes before it would restart.
KARL.
Old 25-10-14, 07:18 PM   #8
andya
andya's Avatar
This problem is getting worse and worse, so is the next issue to get sorted!!
Where will I find the cold start relay please
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 25-10-14, 07:55 PM   #9
It's good that we can guess that we're talking about KV engine...
There's no "cold start relay" - there's only switch which turns on cold start injector when starter motor is running. The rest of enrichment is provided by control pressure regulator.
Old 25-10-14, 08:03 PM   #10
andya
andya's Avatar
Thanks for the reply msh. Yes its the kv engine. I want to eliminate the simple things first. Any thoughts you might have would be much appreciated.
1985 Coupe Quattro
1987 Coupe 2.2 GT
