Classic Audi » Classifieds section » Parts Wanted » Audi FWD NA 4/5 cyl B3/B4 subframe
Old 24-03-14, 07:52 PM   #1
Nuvo
Default Audi FWD NA 4/5 cyl B3/B4 subframe
Hi,
I'm looking for a replacement subframe from a FWD B3/ B4 4 or 5 cylinder car built from 1993 onwards.
If you have one that is free from cracks or dents with light surface then please get in
touch.
Thank you.
Nuvo is offline   Reply With Quote
Old 24-03-14, 10:29 PM   #2
Andy10v
Andy10v's Avatar
3B one any use or do you need different mounts?
2005 350z GT
Sold-1993 ABY coupe
Old 24-03-14, 10:48 PM   #3
Nuvo
Hi Andy,
Different mounts are needed as AWD cars have two additional mounts for the gearbox supports which are absent from FWD models.
Old 25-03-14, 01:54 PM   #4
FWD also used at least one , depending on engine and gearbox configuration. In any case, since you're apparently unwilling to use angle grinder, take out B3 A80 from your list, it has engine mounts attached to subframe
Old 05-04-14, 07:26 AM   #5
farmer phil
farmer phil's Avatar
Will have one for fwd 80/90 b3 b4 pm me
farmer phil is offline   Reply With Quote
Old 05-04-14, 04:17 PM   #6
Nuvo
pm on its way.
