Classic Audi » Technical » Mech/Tech » Electrical problems » rear heated window / radio amplifier
Old 11-12-13, 07:18 PM   #1
Chris Chambers
Chris Chambers's Avatar
Default rear heated window / radio amplifier
Hello, I have a 87 Audi 100 CC avant, the problem is the top half of the heated window is not working, also this is where the radio receiver is,either of which aren't working, however the lower half is. any advice on this matter would help no end. I have checked through the manual for things to be related and I have not yet checked the amplifier unit nor have I checked the fuses, but to my thinking, I thought if it was an issue with fuses surely the whole window would not work. also when i run my finger down the wino the raised heated element parts there seems to be what look like spaces ?
Many Thanks Chris
Chris Chambers is offline   Reply With Quote
Old 11-12-13, 09:05 PM   #2
Ringmaster
Ringmaster's Avatar
Chris,
My 87 CD Avant has no receiver built into the rear window. Are you sure about yours?
Sounds like you have a break in your window's element. If so, I think this can be repaired by using a sort of liquid metal. Not sure what its called but I think I saw it on the Frosts auto restorer's website.
It may be coincidental that your radio and window are playing up simultaneously. Give the fuses a look anyway.
Old 11-12-13, 09:32 PM   #3
moonwatcher
moonwatcher's Avatar
Use a multi-meter with a pin attached to one lead, the other end on the supply to the screen supply to locate the break, then carry out a repair with Bare Conductive Electric Paint, £6 a pen.
Coupe Quattro 1985
Old 12-12-13, 04:30 AM   #4
If "top half" are two stripes used as antenna, remove trim and check amplifier. Heating wire should be connected to amplifier and amplifier should pass the power forward.
Old 12-12-13, 06:20 AM   #5
i think if you're caught doing that, you'll probably get charged!!
Old 12-12-13, 06:49 AM   #6
A4 TOURING
A4 TOURING's Avatar
Location: Usually Underneath a member of the Female Variety . Although reside in Southport North West UK.
Lmao
A4 TOURING is offline   Reply With Quote
Old 13-12-13, 12:19 PM   #7
Chris Chambers
ok cheers will have a look later on today
Old 13-12-13, 12:21 PM   #8
Chris Chambers
well the car was given to me by my late father and he told be that this was the case with the radio and heated element in this particular car, so i will have to really check through
Old 31-12-13, 04:47 PM   #9
Chris Chambers
Originally Posted by Ringmaster View Post
Chris,
i checked in the book and the fuses are shared with other features of the car that currently work
