Classic Audi » Technical » Mech/Tech » Engine » coupe quattro 1.9 tdi
Old 16-12-12, 10:50 PM   #1
Megsy
Default coupe quattro 1.9 tdi
Just wondering if any body has put a 1.9 tdi into a coupe quattro yet ?
as I am looking at doing one next year
Megsy is offline   Reply With Quote
Old 16-12-12, 11:45 PM   #2
No but if you want a complete donor car let me know.
Audi 80 tdi 1z
Old 17-12-12, 01:38 PM   #3
yeti
No, but I keep kicking the idea round. Main problem I can see is finding a 4wd gearbox with suitable ratios?
2003 Cors-arrrgh
Old 17-12-12, 02:00 PM   #4
Brian83
Brian83's Avatar
5 cylinder 2.5 TDI?
Brian83 is offline   Reply With Quote
Old 17-12-12, 02:47 PM   #5
Originally Posted by Brian83 View Post
5 cylinder 2.5 TDI?
You'd need 4WD to handle that torque....
Old 17-12-12, 02:48 PM   #6
quattrostyle
Finding the right gearbox would be my concern also. But then the later boxes had a dual bolt pattern bellhousing so you might be able to use an A4 tdi quattro box or so.
Edit: I don't know for sure if all newer boxes have the dual bolt pattern.
Old 17-12-12, 04:06 PM   #7
Eddy
Eddy's Avatar
I did this to a 80 quattro, fitted a 1.6td from a golf gtd, it originaly had a 1.8 petrol so the gear box fitted. Ran it on veg oil for a few years cos Im a peece loving cheep skate hippy type
As far a gear ratio goes it was great for towing and maxed out at 105mph so not too bad
I was going to do a similar covertion with a 2.2 coupe and fit the 2.5td engine from a vw transporter.
The lazy solution would be fit massive tyres to componsate for the higher gear ratio.
Old 17-12-12, 07:32 PM   #8
20vcqdriver
20vcqdriver's Avatar
5 cylinder 2.5 TDI?
Was about to say the same, much better option, especially if its the 140BHP 5 CYLINDER and use the 6 speed from it too...
Old 17-12-12, 07:52 PM   #9
Or just a 1.9 tdi with bigger injectors and a remap for 140bhp.
Old 17-12-12, 07:59 PM   #10
1781cc
1781cc's Avatar
Can you get 140 from a 90bhp 1z easily? Guessing .216 nozzles, tuning box, EGR delete and a map?
