Classic Audi » Community » General Chat » Compressor Brake bleeding kit buying help
Old 24-03-12, 04:47 PM   #1
saladdodger
Default Compressor Brake bleeding kit buying help
Can anyone recommend a compressor and bleed/vacuum kit please.
Ive seen some on the net, machine mart etc but unsure what i actually need.
Should it be one that attaches to the reservoir and pushes it through to each 4 corners or one that sucks from the nipples??? if that corrects
Any links would be helpful
Thanks
Andy
Old 24-03-12, 06:40 PM   #2
Blackrat
Blackrat's Avatar
I have recently brought and used a one man kit but can't remember what it is called!!!!
It works off the air in the spare wheel, attaches to the top of the reservoir via a container of fresh brake fluid.
It worked a treat and was a doddle to use.
Plenty on the bay for about £15 ish
1982 quad light GT5 S .......92,000..
1976 wife... mileage unknown.. in daily use
Blackrat is offline   Reply With Quote
Old 24-03-12, 07:07 PM   #3
saladdodger
got one, eezibleed, not cutting the mustard mate
Old 24-03-12, 07:11 PM   #4
Hanuman
Hanuman's Avatar
I'm not happy with any of the ones I ever had/have.
If you're not replacing all the fluid in one go, don't bother.
If you are replacing all the fluid, enjoy 4 cups of tea, rather than 2.
Broomstick, spanner, jar, tube with none return valve (cheap from Halfords), Axle stands if you really must.
keep topping up as required.
Old 24-03-12, 09:47 PM   #5
I use one of these:
http://motiveproducts.3dcartstores.c...109_p_101.html
Bought it direct from Motive Products about 10 years ago.
1991 90 quattro
Old 25-03-12, 08:37 AM   #6
b2_sport
b2_sport's Avatar
one of my friends has got one of these;
its excellent, what a doddle! It pressurises from the resorvior so you just crack the nipples release a bit of fluid and lock. I managed to do a Pug 106 on the floor without taking the wheels off under 10 minutes!
Old 25-03-12, 09:47 AM   #7
Cuppatea
Cuppatea's Avatar
Probably quite a bit more than the eezibleed type ones but If you do alot of private work or own a garage then...
http://www.liquid-levers.com/sbb.htm is a good bit of kit. Fluid fed under (adjustable) pressure. Connects to car battery.
Just take care with how much pressure you use on a4's passats with the round resevoir as they tend to burst if old and brittle.
Cheers
Cuppatea is offline   Reply With Quote
Old 25-03-12, 03:50 PM   #8
saladdodger
We have just used a 400 quid jobby my mate has and it was awesome, pushed loads of air out that the eezibleed didnt.
So simple arnt they.
