Classic Audi » Technical » Technical Info » Display Pixelation
Old 09-02-12, 05:40 PM   #1
Andy Douglas
Andy Douglas's Avatar
Default Display Pixelation
Hi does any one know if the information display on later Audis can be repaired,I'm looking at an A6 2.5 TDI and the display is badly pixelated to the point of being unreadable.
Thanks
Andy
No Audi at Present
MGF VVC
Honda CRV (daily wife bus)
Peugeot Expert (work van)
VW Polo 1.9 TDI No 1 sons 1st VAG car
Andy Douglas is offline   Reply With Quote
Old 09-02-12, 05:45 PM   #2
saladdodger
Pretty sure my mates 2001 S3 display was like this, he ended up buying a second had working cluster/clocks
Old 09-02-12, 05:56 PM   #3
Nierca_Quattro
Nierca_Quattro's Avatar
my 2000 a6 has a few missing, but not constantly I'm sure there is a new screen available to buy (not original), but then you have to send your clocks somewhere to get this screen fitted or something. I'll have a look if I can find that page still. I think it's l.e.d screen which will work as a replacement properly and it WILL last "forever".
Old 09-02-12, 06:02 PM   #4
Hanuman
Hanuman's Avatar
I think the display is an LCD, which is clamped down onto a couple of contact pads. If the surface gets dirty, or even a little loose, the display goes random. At least, this is how the centre display is on one of mine.
It may be worth simply opening it up, cleaning the contact surface and reassembly.
Old 09-02-12, 07:16 PM   #5
Very common fault, which is repairable. http://www.clusterrepairsuk.co.uk/re...yna/?make=audi
Old 09-02-12, 07:25 PM   #6
Nierca_Quattro
Can't find that page mate.. But there's some on ebay aswell.
Old 09-02-12, 07:41 PM   #7
ChrisG
ChrisG's Avatar
I can thoroughly recommend clusterrepairs - at least in Great Yarmouth !
£150 and done within the hour.
New display, better connectors/wiring anda 5 year warranty.
Actually it cost nmore than £150, as we went shopping so it was M&S Debenhams Costa Palmers ( large dept store - bit oldy worldy ... but OK !)
Old 10-02-12, 12:14 PM   #8
al_bundy
It's the display itself. Only way to fix it is to replace the display inside. It has a fine-pitch connection and is soldered on the cluster. If you never soldered some fine electronics then you'd better bring it away.
A new original VDO display costs ~80 euro, see ebay item 140688583568.
I've changed some displays the past 3 years. Keep in mind that Audi also used a Jaeger cluster, the VDO display can't be used for these units. You need a specific (only after-market) display for it.
How to check: if the backside is completely black it's a VDO. If a large part is white it's a Jaeger.
al_bundy is offline   Reply With Quote
Old 10-02-12, 01:33 PM   #9
audivw
Banned
Cool
i did my own
here's a link to show you how
http://www.audifans.net/ftopict-36210.html
audivw is offline   Reply With Quote
Old 11-02-12, 07:08 PM   #10
Andy Douglas
Thanks for all the replies,not too much of a problem,the A6 I was looking at is a very tidy car with a good history,but a bit to expensive at the asking price, the brakes need serious attention new, disks and pads all round and perhaps a couple of calipers, it does have some other problems to sort so I'll pass on this one,
No Audi at Present
MGF VVC
