Classic Audi » Technical » Mech/Tech » Engine » 16v Knock sensor,where does it connect??
Old 11-04-11, 04:24 PM   #1
SteveCat
SteveCat's Avatar
Default 16v Knock sensor,where does it connect??
Hey!
The knock sensor on my 16v Coupester is connected at the plug.
However,it appears to have been disconnected by someone in the past.I know some folk loosen them to pep up the pace a bit,without knowing the consequences!
Piccies would be really helpful if someone could?
I've had my head down the back of "the" head and torched from underneath.
Im assuming the bolts long gone too.So,in essence,Im looking for a hole.ahem
Mercedes E220 Sportline Coupe
Old 11-04-11, 05:06 PM   #2
What are you looking for - for connector or place where to put bolt for missing knock sensor? 16v engines has two knock sensors and all 4 pot engine blocks has mounts for both, despite the fact that 8v uses only one. Find remaining one and another will be in similar place Both mounts are between two pots - one between 1st and 2nd and one between 3rd and 4th on block side called passenger side in UK.
Old 11-04-11, 05:09 PM   #3
Ben
IIRC it's bolted on the inlet side of the engine block, just below the head. I think there are two knock sensors.
1992 80 quattro 20vt
Old 11-04-11, 06:40 PM   #4
SteveCat
SteveCat's Avatar
Default .
Thanks guys!
Shall get looking after Eastenders
