Classic Audi » Technical » Car detailing & polishing » Headlining
Old 14-07-08, 01:41 PM   #1
foxracing
foxracing's Avatar
Default Headlining
Hi Coxy
can you recommend something to clean my headlining? its a b3 Coupe, its really dirty and looks disgusting.
foxracing is offline   Reply With Quote
Old 15-07-08, 10:26 PM   #2
Presuming it's the fabric stuff, then I'd start with something like Autosmarts Brisk foam stuff.
It's in a spray can and you spray directly on to the headlining and then work in with a soft brush to loosen the dirt. It's a thankless task trying to remove tobacco stains but will soon get rid of the dirt.
Warning, by the time you've done the whole roof, your neck will ache!
there is also a product called woolite out as well which has been getting some good reviews
Old 16-07-08, 12:48 PM   #3
foxracing
foxracing's Avatar
Thanks mate, I'll give it a go, may have to take the seats out as it's a bit cramped in the back
Old 04-08-08, 09:20 PM   #4
Octanejunkie
Octanejunkie's Avatar
Don't be too agressive though! Old headlinings have a propencity to be a bit on the fragile side and can split or come away easily.
Sloooow and steady
