Classic Audi » Technical » Mech/Tech » Engine » Excessive fuelling on 2.0 8V coupe
Old 12-11-10, 06:46 PM   #1
Timo
Default Excessive fuelling on 2.0 8V coupe
As above, my newly acquired 1996 2.0 8v coupe seems to be using excessive fuel.
I ran the tank to empty yesterday then put £5 in, drove to coxy's and back today (very carefully) which is a round trip of 22 miles and the tank is empty again! So the car is doing about 22 miles per gallon if I nurse it which is well below book figures, not only that it seems worse than my old 16V and coxy's 20V!
Weirdly the car does not smell excessively of fuel when its idling as you might expect if there was a leak or was running rich. Also I've checked the air filter in case that was blocked and causing havoc with the MAF sensor but that looks nice and clean.
If anyone has any suggestions on what to check next that would be great as I'm a little unsure where to look next.
Cheers
Tim
1969 Burgundy 912
Old 12-11-10, 06:53 PM   #2
Drop the 16v in!
Old 12-11-10, 06:54 PM   #3
rich.r
is it possible you are actually losing fuel from some where maybe filter or similar as opposed to running rich
Old 12-11-10, 06:55 PM   #4
Timo
Drop the 16v in!
Might do at this rate, problem is its missing a few bits now! Also if I did drop the 16V in would I have to go back to a CAT exhaust for the emmisions test as the 16V was a 1993 and the 8V is a 1996?
1969 Burgundy 912
Old 12-11-10, 06:58 PM   #5
Timo
Its possible but as I say the car never smells of fuel and I've never noticed any leaks on the ground where its parked. The fuel pump does have a slight whine but I'm not sure this is of any significance.
1969 Burgundy 912
Old 12-11-10, 07:03 PM   #6
rich.r
if your loosing it when its running/moving you wouldnt notice it so much and the wind would push smells away from you
Old 12-11-10, 07:13 PM   #7
Timo
Hmm, you might have a point but wouldn't it be losing it when stationary too?
1969 Burgundy 912
Old 12-11-10, 07:15 PM   #8
SkinnyMan88
SkinnyMan88's Avatar
Mine used to run at about the same mpg, pretty much exactly the same! And I never smelt any excessive fumes or anything but changed the lambda sensor and started getting around 35 mpg.
The old one was black as anything, no wonder it wasn't working! Might be worth a look.
Also, the cold start valve / fifth injector stick open aparently. You just need to warm the engine up, pop it out and plug the hole then turn the engine back on, it shouldn't release any fuel when warm.
Hope that helps
SkinnyMan88 is offline   Reply With Quote
Old 12-11-10, 07:19 PM   #9
Timo
Thanks Skinny man, will take a look at both those suggestions.
1969 Burgundy 912
Old 12-11-10, 07:26 PM   #10
SkinnyMan88
Problem is, the injectors are pricey (around the £100 iirc ) but easy to fit. The lambda sensor is less so (I paid about £60 I think) but a ballache to fit lol.
The cost is offset in what you save on fuel though, at least
Good luck, hope you get it sorted.
