Classic Audi » Technical » Mech/Tech » Engine » LPG on an i5 turbo?
Old 02-06-08, 11:34 AM   #1
wedgedout
Default LPG on an i5 turbo?
Has anyone done this?
wedgedout is offline   Reply With Quote
Old 02-06-08, 06:23 PM   #2
joe90
Theres a place in Rochdale Lancashire does anything from a carbed small block chevy to brand new motorhomes and most things in between. I've been twice with my father in law, he had a voyager then a jag done, the owner says he can fit lpg to anything and he can program it to run better on lpg than on petrol. If you want ill get you a number.
Old 02-06-08, 06:45 PM   #3
I want to get my 2.3 100 LPGd soonish (once it is running fine), then I will swap the engine for a 5 pot turbo (eventually!).
Apparently the turbo engines like LPG because it has a lower compression ratio... don't know where I heard it, or if it is true/????
Audi 100 turbo engine into non-turbo Audi 100 pimpdriver Engine 18 09-05-08 02:18 PM
