Classic Audi » Classifieds section » Parts For Sale » KN Airfilter and custom 60mm TB for 5cyl coupe
Old 29-06-10, 08:47 PM   #1
moomin
Default KN Airfilter and custom 60mm TB for 5cyl coupe
Afternoon all,
Sold my 5 cyl coupe a while back but found some bits in the garage some people might want.
First up is this 60mm Throttle body, this is a direct replacement for the twin butterfly version found on all audis of the 1980s era.
The difference...
You will need to adapt your throttle linkage and setup an idle bypass with any form of adjustable valve (I used a boost control valve)
£35 inc P&P - TB, adapter and bolts.
Next up is a K&N panel air filter, one of those last forever easy clean jobs. Fitted my '84 5cyl coupe did about 300miles with it. Will do 30000miles before it needs cleaning with petrol apparently.
£15 inc P&P
Contact through here.
Thanks,
Adam
moomin is offline   Reply With Quote
Old 03-07-10, 11:38 PM   #2
Dablad75
Dablad75's Avatar
Default filter
ayup, up for the air cleaner, ok to post to sheff?
Dablad75 is offline   Reply With Quote
Old 04-07-10, 07:22 AM   #3
Do you get running problems with it at low revs?
Old 04-07-10, 07:00 PM   #4
moomin
Air cleaner provisionally sold.
No "problems" at low rpm but it ceratinly moved the torque band higher up the range
