Classic Audi » Technical » Mech/Tech » Interior » Help! Locked key inside car
Old 15-06-10, 11:40 AM   #1
Bowma
Bowma's Avatar
Default Help! Locked key inside car
Can someone please help! I have left my car key inside the car when I locked the door, I have only one key. The drivers side door lock doesn't work with the key so I have to lock the car by pushing the button inside, so I forgot to take my key. Is it possible that somehow I can get another key perhaps from an Audi dealer? Can someone please suggest something? Thanks! It's an Audi 80 1986 1.8.
Bowma is offline   Reply With Quote
Old 15-06-10, 11:48 AM   #2
stuartmmcfc
think your self lucky. I once did this in a carpark with no mobile phone and my baby daughter strapped in inside
Anyway, when the AA came he had several plastic "wedges" which he used to lever the door slightly open on the B pillar and then slide a peice of long tie-wrap, through the gap, to hook and then unhook the lock.
Took him about 30 seconds.
Old 15-06-10, 11:49 AM   #3
Martc
Black Coupe Collector
Martc's Avatar
4 Options
1. Key from Audi - will take a couple of days and you will need the chasisis number and probably some documentation
2. Breakdown / security company to come and break into the car
3. If the button is raised, get a plastic packing strap fold it in half lengthways so its in a loop and pass it down between the door rubber and frame into the car and looped it round the button and pull it up (done this a few times)
4. Brick through the window.....
95 UrS6
87 Coupe Quattro
Old 15-06-10, 11:54 AM   #4
stuartmmcfc
3 Options
3. If the button is raised, get a plastic packing strap fold it in half lengthways so its in a loop and pass it down between the door runner and frame into the car and looped it round the button and pull it up (done this a few times)
yep no.3 was the AA way
Old 15-06-10, 11:57 AM   #5
eltee
eltee's Avatar
try another similar key in the drivers door as the tumbers tend to seize up, or try the passenger door lock.
to organise a key from the dealer usually takes 3 to 4 working days. as long as the car hasnt had a complete lock change.
88 100 cs sport
Old 15-06-10, 12:28 PM   #6
tttoptotty
tttoptotty's Avatar
Metal Coat hanger bent into a loop string on the end of it longer than coat hanger slip between window rubber and door put loop over door button oull tight and up this should open it for it let us know how you get on should take about 10 seconds. Failing that Audi do sometime have skeleton keys that may work and so do the police so they may help you as well
Audi the ride of your life
Old 15-06-10, 12:34 PM   #7
Being blonde..... I bet you have done this Sharon even when the roof was down
Old 15-06-10, 12:46 PM   #8
tttoptotty
tttoptotty's Avatar
God that nearly made me laugh Rich. No but my mazda was a pain in the arse if you got out and shut the door it would immobilze it's self so I used to have to unzip the back window and climb in get the keys reset the fkn thing and then drive off dont you just love em!
Old 15-06-10, 12:47 PM   #9
come on you two, flirt on your own thread!
Old 15-06-10, 12:49 PM   #10
tttoptotty
tttoptotty's Avatar
PMSL dont you just love the the banter. I did put a serious note on honest
