Classic Audi » Technical » Car detailing & polishing » Door Ring Stickers Positions Required - B2 CQ
Old 18-04-20, 08:22 PM   #1
andya
andya's Avatar
Default Door Ring Stickers Positions Required - B2 CQ
As per title, if somebody could measure up for me I would be most appreciated, or if there is a guide somewhere.
No rush at all!
Many thanks in advance
1985 Coupe Quattro
1986 Coupe 1.8 weber carb
1987 Coupe 2.2 GT
Old 18-04-20, 10:07 PM   #2
If they’re OEM they’ll come with a spacer tab.... So the ring panel will be
=[OOOO] shaped....
The = spacer tab is the correct door jam to decal start space.
Similarly, the CQ/GT rings are smaller than Ur rings to accommodate the rubbing strip, so watch for this.
Finally, it’s equidistant between the rubbing strip (or lower swage line on Ur) and the door bottom, but this seems to be hit and miss even in period correct applications as they appear to be dealer applied rather than factory.
Old 19-04-20, 06:37 AM   #3
andya
andya's Avatar
Many thanks Ian.
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 19-04-20, 07:25 AM   #4
Colin Aitchison
Colin Aitchison's Avatar
Detailed sizes below from Ur quattro.
Old 19-04-20, 07:29 AM   #5
andya
andya's Avatar
Superb! Many thanks Colin
1985 Coupe Quattro
1987 Coupe 2.2 GT
