Classic Audi » Technical » Mech/Tech » Engine » Fuel to engine problem Audi 80 Sport 84'
Old 03-03-10, 01:48 AM   #21
nickt241
take a visit to the scrapyard or buy a 2nd hand one off here,im sure someone will have one,you should get one for under 20 quid 2nd hand....if the scrap yard aint got an audi pump then look for anything older ford,granny,scorpio,sierra etc etc,with fuel injection,the pump is located on the outside front of the tank underneath,these pumps will power any make of fuel injection and are simple and reliable,ive used them on all sorts from jags to jap stuff......there is a very slight chance that the pick-up inside the tank has worked loose,simple way to test this is to fill the tank right up,if problem stops,then get yer spanners out cos your dropping the tank......but,this is doubtful and my geuss is that if you follow the steps ive listed then youll cure your problem long before you need to spend 60 quid on fuel!
nickt241 is offline   Reply With Quote
Tags
audi 80 sport, engine problem, fuel pump.
